hi hello hola
Discussion in 'Newbie Forum' started by 007cowboy, Oct 28, 2019.
  1. 007cowboy
    007cowboy New Member
    usa
    new and just saying hello. seems like the thing to do.
    so, hello
    '07 prius owner may get a '10.
    nice forum
    Burna J and bisco like this.
  2. Moving Right Along
    Moving Right Along Senior Member
    731
    588
  3. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    Shalom!
    Keep the '07 and save for a '15.
    007cowboy likes this.
  4. bisco
    52,350
    bienvenue!
  5. 007cowboy
    usa
    why that model year?
    thanks!
    Greenteapri likes this.
  6. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
  7. ETC(SS)
    7,332
    Welcome Aboard!
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I hope you enjoy your '07, I wish I trusted the Gen 3 Prius enough to recommend a '10.
    If you do get one, strongly consider getting the EGR system cleaned.
  9. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    The pistons and piston rings were upgraded to potentially mitigate oil burning that seems to be common in prior year models.
  10. Greenteapri
    330
    387
    Cypress
    Toyota updated the plagued Gen 3 engine with new internals; specifically new pistons and piston rings.
    Search - Burning oil, EGR, Blown head gasket.
    Your Gen 2 Will run longer.
  11. 007cowboy
    usa
    i'll read. thanks all for the heads up.
    i was looking to get a used '10 at auction for the wifey cause she's growing on the prius. buuuuuuut i'll wait it out and stick with what we have for now.
    THANKS everyone
    mikey_t likes this.
  12. bisco
    52,350
    if you can find a low mile gen3 that you can afford, there are things you can do to mitigate these problems
    or, you could look for a nice 2009
    mikey_t likes this.
  13. Moving Right Along
    731
    588
    The last year of gen 2 (2009) and gen 3 (2015) seem to be the most reliable Prius models to get, in comparison to other years in each generation. If Toyota follows the same pattern, the 2021 gen 4 should be very reliable as well.
