Heat Shield, Engine Coolant, and Hybrid Water Coolant Replacement Qs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pandas Andpresents, Nov 1, 2019.
  1. Pandas Andpresents
    Pandas Andpresents Junior Member
    40
    Lexington, MA
    Hi All,
    I had a rattling noise start under my hood during a recent long trip. The dealership is telling me that the heat shield needs to be replaced. They said the charge is $277 inclusive of labor and parts, but not taxes.
    My questions: Is doing this DIY possible and, if so, how much could I potentially save? Also, is driving it like unrepaired until I can get parts potentially harmful to the car?
    Also, I am due for engine and hybrid water coolant replacement. The dealership is telling me the charge for these services would be $220 and $160, respectively. Is that typical? I tried calling other Toyota dealerships. Maybe everyone is at lunch? No one in service picked up at the three places that I tried.
  2. ASRDogman
    ASRDogman Senior Member
    7,725
    3,960
    95% of repairs on a Prius a DIY. Remove the labor cost from the dealer's price, that's at LEAST
    what you won't spend.
    And they are really easy repairs.
    Search on prius chat for video, and youtube. Nutzandbolts videos are pretty good.
    I don't know what heat shield, maybe a screw or bolt is just loose. Driving without it probably won't
    create a huge problem, but it's there for a reason...
    Pandas Andpresents likes this.
  3. Mendel Leisk
    41,786
    If you can get the car safely raised you'll have no problems (y)
  4. Pandas Andpresents
    40
    Lexington, MA
    Okay, TY! It's the front heat shield. The person at the dealership said that without it, my feet would get very hot while driving. When I first heard the noise, I was pretty alarmed because I had just finished a long drive (CT to Montreal and back). I thought it was a much more serious problem.
  5. Pandas Andpresents
    40
    Lexington, MA
    As with most repairs re: this car, that is the rub. Can't even do an oil change on this thing with lifts - argh! Okay, TY!
  6. Eddie25
    Eddie25 Active Member
    497
    209
    MI
    The heats sheilds often rust out in circles around the nuts that hold them up. On my car I just cut out pieces of flashing from the hardware store like giant washers, drilled holes in the middle and installed them like a washer. Worked fine and no more noise. I can't say that's the best way or even a good way to fix it but it's worked so far and cost about $5.
    Rebound and ASRDogman like this.
  7. Mendel Leisk
    41,786
    No chance of floor jack and safety stands? Or ramps? Either will do the trick.
    I think most of the heat sheilds are aluminum? There's a hardware store item called a "car washer", basically an oversized washer (small hole, large outside diameter). Get galvanized if possible.
  8. Eddie25
    497
    209
    MI
    I think it's the nut that rusts causing corrosion on the aluminum in a circle around the nut, or maybe rust actually cuts into the aluminum? Whatever it is I had to fix most mine but I would say it's definitely DIY worthy.
  9. Mendel Leisk
    41,786
    The nuts/screws on our Prius rust when you look at them. Maybe new regulations regarding protective coating, who knows. I've been coating everything I see rusting with boiled linseed oil. It seems to hold up good, and stops rust in it's tracks. Close to the muffler I guess you need to be careful, but the heat shields are usually a bit away from anything really hot.
  10. frank lyons
    frank lyons Junior Member
    dubuque
    replaced mine with fender washers from a hardware store. easy to do. worst part is getting under the car.
  11. Mendel Leisk
    41,786
    If there’s bolts screwing into weld nuts, proceed very cautiously when trying to remove them; they can get rust-seized and you’ll snap the head off. If they’re stubborn, a squirt of penetrating oil beforehand may help, and try to “shock” them loose, either with an impact gun or a manual impact, the kind you rap with a hammer.
