12v Battery Issue?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by CPost, Nov 1, 2019.
  1. CPost
    CPost Junior Member
    Raleigh NC
    Hey Guys,
    Need some advice.
    I have a 2007 Prius with 81k. I live in Raleigh, NC. Yesterday it was 80 degrees, this morning it was in the low 40's. My car ran fine yesterday. When I went out to go to work this morning, the car would not unlock. The key fob wouldn't work. It worked fine yesterday. I took the manual key out and opened the door. I started the car and the radio / clock / mpg on the computer were all reset. Does this have something to do with the drastic change in temperature or do I have a bad 12v battery or is it just a bad connection?
    Thanks,
    Chris
  2. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Most likely the 12v. Can you test it with a multi-meter or a voltmeter?
    When was the last time the battery was replaced?
  3. CPost
    CPost Junior Member
    Raleigh NC
    The 12v has not been replaced. I'll test it. Thanks!
  4. EternalPrius
    EternalPrius Junior Member
    Pasadena, CA
    Three Touring
    these batteries are usually killed by time more than use. 12 years is a good service life. just use a volt meter to check it. might be good to replace the fob battery, it takes two minutes. get a battery from the dealer, it's worth the extra $.
    cyberpriusII likes this.
