Lower Control arm replacement. Trouble removing them.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mypriuscious, Nov 7, 2019.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,520
    2,510
    Taylors, SC
    The bolt in the issue is Toyota Part #90105-A0250. The end is screwed into the mail cross member, which is Toyota Part #51201-12442.
    The bolt is threaded into a "captive weld nut" in the main cross member. You need to examine the cross member to determine if there is an access point to see the captive nut. There is where the heat and/or penetrating oil needs to be reapplied.
    When torqued to a high value, the bolt is under high tension. You might have to cut away the eye of the control arm to relieve the tension on the bolt. This would relieve the tension, resulting in the bolt held to the nut only by friction of the threads of the bolt and captive nut and maybe some corrosion.
    The weakest point of the bolt would be at the point of the smooth shank and the start of the thread and the part inserted into the captive nut. This is where the bolt would be most likely to break. Cutting away the eye of the old control arm is likely the best option.
    If the bolt is broken, a carbide burr needs to be used to dimple the broken bolt in the center. The hole then needs to be drilled into the bolt with a cobalt alloy high speed streel drill bit to the minor diameter of the threads of the bolt. Then, the hole needs to be re-tapped. if the threads are destroyed, a thread insert like a Heli-Coil or a Timesert needs to be installed. Not having examined the bolt, but my familiarity with Toyota suspension components says that the thread is most likely J.I.S. M16x1.5 or even M18x.1.5.
    #21 Georgina Rudkus, Nov 8, 2019
  2. Mendel Leisk
    41,969
    Find out what the shop is using first. The torque on that is 170 something foot/pounds IIRC. To break that loose you want a significant breaker bar (not a ratchet with cheater pipe, if that's what they're using). Also, something like Milwaukee Tool's 1400 foot/pound 1/2" impact might do it.
    As far as heating the captured nut, if that's not practical, try to chill the bolt? There's a spray for doing that and applying a penetrating lube at same time, I think?
    I appreciate a bolt torqued to 170, then subsequently rusted up for a few years, is going to take some oomph to break loose, much more than 170.
    Georgina Rudkus and mypriuscious like this.
  3. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    The two half inch tools he broke are Chinese made tools. Take that for what it is worth. I DL'd and printed out the repair manual pages you posted, thank you very much! I brought over my Milwaukee "1400ftlbs of nut busting torque" over and it didn't move it a bit. I was very surprised. He had a couple different length breaker bars he used in front of me, longer than 30 inches.
    I appreciate everyone's comments, suggestions and input. The car is at the mechanics now and I wish I would have taken pictures while I was there Thursday, but I will go tomorrow to talk to him and offer the suggestions that you all have made.
  4. Mendel Leisk
    41,969
    Then I think Georgina's ideas are what's needed, lol.
    Good luck!
    mypriuscious likes this.
  5. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    I love that tool, I have 3 of them and one of the older models. One for each car and one for the tool box.
  6. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    I've copied and printed this out. I was thinking today that the crossmemeber might have to be removed with the control arms attached to gain access to that captive nut.
  7. Mendel Leisk
    41,969
    They're $600 CDN (with two batteries, charger and case) up here, I just can't justify it. Yet...
  8. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    I have so many batteries anymore and I used to love the cases but now they just take up space. The 3 I bought each came with one 5.0 battery and the Impact for 249 USD per unit. Milwaukee is my brand so I've got at least 10 chargers around here. It definitely was a luxury purchase though. HomeDepot.
  9. Mendel Leisk
    41,969
    Yeah tool-only on sale for $250 CDN.
    RMB likes this.
  10. Georgina Rudkus
    3,520
    2,510
    Taylors, SC
    Time to get an air impact wrench and try that. I have the equivalent Makita battery powered wrench and find that it does not have the same power as my air wrench.
    If that doesn't work, using an angle grinder and an abrasive cutting wheel, cut the end of the control arm through the entire bushing and the a bolt across its axis a little more than half way from the head. Pull off the head end of the bolt. Cut off that end of the control arm loop with half the bushing and discard it. Slide the rest of the control arm off the remaining bolt and remove it. Having relieved the tension on the bolt Using a Vise Grip, remove the cut off stud from the captive weld nut. If it refused to move, use penetrating oil or heat as needed.
    #30 Georgina Rudkus, Nov 9, 2019
    James Analytic and Mendel Leisk like this.
  11. Mendel Leisk
    41,969
    @mypriuscious I notice some reference to other Repair Manual section, in the previous info I attached. I've attached what I think that is. I haven't read through it that carefully, so if you need more just ask and I'll try to find it.
    Georgina Rudkus likes this.
  12. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    Looks like it an instructional for removing and replacing the front wheel bearing.
  13. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    Has anyone ever removed the crossmember as per toyota to replace these parts? If you have, were you able to access the "captive weld nut" or even see it while removed?
  14. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    Here's a little update for those who are curious, the control arms are out. Had to drop the crossmember to do it. And some advice on r/mechanicadvice on reddit, one user said he had to cut a hole into the crossmember to lube and heat treat the captive nut. Well, it wouldn't come loose. Had to cut the captive nut free and then cut the bolt because it was not coming out of the control arm. It was a slice and dice job. Then the premium parts from NAPA wouldn't fit so I had to order new ones from Toyota. If I can get pictures I will post them.
  15. Mendel Leisk
    41,969
    The captive nut is boxed in, inside the cross member? The bolt is the highlighted one?
    I just revisited the rust proofing on that area, and kinda looked, got the impression you can't even see that nut, let alone get to it. Isn't road salt just great... :mad:
    #35 Mendel Leisk, Nov 16, 2019
  16. Georgina Rudkus
    3,520
    2,510
    Taylors, SC
    That's why early in a car's life, I always spray rustproofing into the hollows of all undercar beam cavities to make sure the places of the welded on captive nut is covered.
  17. Georgina Rudkus
    3,520
    2,510
    Taylors, SC
    I would try everything possible before cutting into the control arm mount or the cross member.
    As I stated previously, if you cannot remove the bolt, saw the old control arm off at the eye that hold the bushing attached to the mount. Saw through the remaining control arm remnant at least half way past the head of the bolt, pull out the sawed off bolt by its head, remove the piece of the bushing held by the headed section of the bolt, slide the remaining part of the bushing into the space left by the removed bushing half to remove it.
    You are left with about half the bolt between the ears of the bushing mount. This allows access to the place where the bolt threads enter the captive nut to be soaked in penetrating oil, while still providing enough of the bolt to hold and to twist it with a locking pliers to remove it.
  18. Kuang
    Kuang Member
    37
    US
    Yes, mine is 2010 with 350k right now and original engine.
  19. Tande
    Tande Active Member
    550
    337
    Mich.
    OMG! ......I need to follow you around! .......;)
  20. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    Might I suggest pulling those bolts out and putting something on them. lol
    This has been a whirlwind of frustration. I live in Cincinnati and I have never experienced such a large bolt becoming so difficult, smaller bolts, yes. But golly.
    Though this car did spend its first 3 years and 75,000 miles in Chicago (I purchased it used). I can only imagine that certainly added to the already flawed design by Toyota.
