Clicking from HV batter area when attempting "ready"
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by labumm, Nov 9, 2019.
  1. dolj
    dolj Senior Member
    7,651
    3,862
    Wellington, New Zealand
    Thanks for the info Chap, informative as always. Agree re NiMH SoC. The point where these batteries do the rapid drop is ~192 V (1.14 V per cell/6.8 V per module). From my graphing of the voltage behaviour while discharging it is reasonably linear above this until ~220 V (1.31 V/7.86 V per module).
  2. labumm
    labumm Junior Member
    57
    The scan tool is OBDLink MX Rev 1.3
  3. ChapmanF
    15,589
    Oh hi again! Anything changed with your issue in the last couple months?
    At the time of that post, it was looking like another choice of scan tool might be in order, to get status from the HV ECU.
  4. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    That adapter should be fine, which 'app' are you using, some will use Hybrid Assistant, Torque, or Dr Prius. There are others Apps as well.
