Prius annoyances
Discussion in 'Prime Main Forum (2017-2022)' started by Zed Ruhlen, Jun 13, 2019.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    If you don't like it so much, get a different car.
    utsug and Salamander_King like this.
  2. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    Invest in some RainX.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    Yeah, you DEFINITELY don't want to back into a cop car. The others probably aren't as big of a big deal, so it's nice to know if the vehicle you see behind you is fair game. :D
  4. Trollbait
    12,507
    Going by some posts, I can say the death of the sedan and rise of the SUV is because of rear wipers.
    Salamander_King likes this.
  5. Marine Ray
    1,139
    947
    Sparks, NV
    Although it would be helpful if there was an "always on" rear camera view like the Tesla.
    Zed Ruhlen and Bob Comer like this.
  6. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    I didn't crop anything. That's the picture my phone took. That's what you see. Actually the iPhone camera has a better image since it is processed by the phone. It's just a major fail.
  7. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    Sedans don't have the same issues typically.
  8. Mendel Leisk
    41,344
    All I'm trying to say is "beyond" the left and right limits of your picture, due to the sloping belt line and c-pillars, visibility gets even more obscured.
    I'm in agreement with you. ;)
    Zed Ruhlen and Data Daedalus like this.
  9. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    Rarely -- the angle of the window is much sharper. With the rear windows defroster running, everything just runs off.
    I would suggest you should turn on your rear window defroster, it would have helped.
    That said, I don't like the rear window either, and I didn't like the hatch in a 2010 Prius any better -- I would much rather have a small sedan, but nobody makes one that fits the role of my prime, it's simply the best. That doesn't stop me from wanting more though!!
    Zed Ruhlen likes this.
  10. Mendel Leisk
    41,344
    If memory serves, it was with the Echo, that Toyota started this "trend" to front-to-rear upward-sloping beltline. That means when you shoulder-check, there's precious little window area to see through.
    ^ I really don't "get" this, looks wrong; like the suspension is messed up, or God knows what.
    #150 Mendel Leisk, Nov 14, 2019
    fuzzy1, Bob Comer and Data Daedalus like this.
  11. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    It does look weird, but strangely enough, I actually like it! Just because it looks so odd and kinda ungainly......like a newly born foal....
    iPhone 6s +
  12. Trollbait
    12,507
    Sedans have had a slope to the rear window like the Prius top one for quite some type. In inclement weather, the view out my Camry's is just as bad as your Prime's, except I don't have a clear second one.
    The defroster helps with snow and ice, but not much with a mild drizzle.
  13. Bob Comer
    708
    460
    It helps with the fogging from light rain, you can see it in his picture...
  14. Trollbait
    12,507
    It will help with fogging, but not much with the obstructing water on the outside.
    fuzzy1 likes this.
  15. Bob Comer
    708
    460
    No, it doesn't help with the water, but it does help you see, which is the real goal.
  16. Trollbait
    12,507
    When the water is a sheet, or fine drops, removing the fog doesn't help much in regards to seeing.
  17. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    Data Daedalus likes this.
  18. bisco
    51,851
    rain y?
  19. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    The difference between a Camry and a Prius Prime is that the rear window in the Camry has a fairly steep angle whereas the Prime's window is basically flat.
  20. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    I am the one who dose not miss the rear wiper on my PRIME for I rarely need to look the rear of my car using the rear view mirror or I already have way too much cargo in the back that even if there was a wiper I would not be able to see through anyway.
    That being said, I wonder what was the rational behind the car makers to equip almost all SUV (and minivans) with a rear wiper and not sedan or coupe. I've had numbers of sedans and coupes that had fairly flat rear window but did not come with a wiper, but as far as I can remember all of our SUVs and minivans had rear wiper even though the rear window was almost vertical.
