Help please-Parking lot hit & run-now have broken rear directional and reverse cover assembly
Discussion in 'Prime Main Forum (2017-2022)' started by MMBH, Nov 16, 2019.
  1. MMBH
    MMBH Member
    155
    43
    Does anyone know if I can just buy an exterior rear clear replacement cover for the reverse and signal unit - versus the whole assembly unit?
    The lights/bulbs, etc still work fine. I covered it with clear packing tape which worked great for the summer, but now that we are getting snow, I'm thinking I need to get it fixed.
    I saw the price online for the assembly unit is almost $500 though and was hoping that one of you's might know if there is an after-market option for just the plastic cover versus the whole assembly.
    I'm so bummed about this car. I think it is cursed. I initially had an $8K repair bill right after purchasing it due to the nose being longer than my gen-2 Prii's, hence when I went to back up and turn it around in my driveway, I somehow clipped the perfect spot in the concrete flagpole stand and pulled the front end nose halfway off around the flag pole situated to the side of our driveway) ---- followed next during the Spring by somebody opening their SUV door into mine and leaving a 4 inch gash in the paint on the rear door... then followed up by this broken rear plastic assembly cover while it was parked all the way in the rear of the parking lot at work.
    I'm at the point of replacing it with a leftover model in the Advanced line, but I have less than 12,000 miles on it and it haven't even broken it in mileage wise.
    So, I'd appreciate it if anyone knows if there is anywhere to get just the cover vs the whole assembly unit for much less than $438 with tax quoted by the local Toyota dealer.
    Thanks in advance!
  2. schja01
    schja01 Senior Member
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    If one exists a local junk yard can probably confirm its existence and track one down from a totaled vehicle.
  3. Elektroingenieur
    2,515
    3,285
    Three Touring
    The cover isn’t available separately as a service part; see catalog Figure 81-11, Rear Combination Lamp.
    Toyota dealers selling online advertise the assembly, however, at prices as low as $266, plus shipping and tax; try a Google search for the part number, 81531-47010 (right) or 81541-47010 (left).
  4. MMBH
    MMBH Member
    155
    43
    Ok, I will check it out! :) It's a little better than having to pay full-price from dealer! Thanks again! :)
    Elektroingenieur likes this.
  5. MMBH
    MMBH Member
    155
    43
    I was wondering about that as a possible option as well. TY! :)
  6. MMBH
    MMBH Member
    155
    43
    Does anyone know if a 3D printing place could make me a replacement cover?
  7. kenmce
    kenmce High Voltage Member
    1,547
    521
    NY
    They would need either the laser scanner setup to scan in an original or an existing file with the specifications.
