Remote Start on Prius Prime
Discussion in 'Prime Accessories and Modifications' started by HappyJuice8000, Jan 6, 2017.
  1. MMBH
    MMBH Member
    155
    43
    Do you need an Advanced Prime or will it work on the other models too, such as the Premium?
    49,796
    he hasn't been around for a few months. if he doesn't reply, pm him and ask if he is making any progress. i suspect a stumbling block, but it probably just takes a long tome to get something like this into production
  3. vvillovv
    vvillovv Senior Member
    3,772
    1,319
    NY
    After watching the video for 5 or 6 minutes, I can only imagine what was happening inside the Primes computers.
  4. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    In the following scenario, will the ICE start and will the last set heater controls be used on remote start:
    • return from work late afternoon (~5:30 PM) and plug in to charge the Prius Prime traction battery
    • hybrid mode is selected
    • at approximately 10 PM, the charger is unplugged from the PP and the charge port door is closed
    • the traction battery is fully charged or has some level of charge the next morning
    When using the remote starter to start the PP the following morning (~6:15 AM) will the ICE start and will the last set heater controls be used?
    #24 eow, Oct 31, 2021
  5. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    I can now answer my own question having had a Compustar remote starter installed a month ago.
    The ICE does start and so does the windshield defrost come on when using the remote starter, as long as the charge cable is not connected.
    iPhone ?
  6. MMBH
    MMBH Member
    155
    43
    just an fyi… that link is now dead for all intents and purposes
  7. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    #27 prius16, Nov 15, 2022
    MMBH likes this.
  8. MMBH
    MMBH Member
    155
    43
    Ty, although it was more of an fyi for anybody that might have been here subsequently ;)
