Featured RAV4 Plug-in Coming In 2020 (Page 4 for deets)
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Danny, Oct 10, 2019.
Thread Status:
Not open for further replies.
  1. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    I think it's an A/C for A/C - as it doesn't have a reverse cycle. I was told that the term "Heat Pump" is generally used to describe an A/C with reverse cycle to heat as well.
    telmo744, meeder and bisco like this.
  2. alanclarkeau
    7,041
    7,580
    [Courtesy of GOOGLE]
  3. Trollbait
    11,325
    I thought they had to walk uphill both ways in the snow.
    alanclarkeau likes this.
  4. Zythryn
    Zythryn Senior Member
    6,171
    4,163
    They did... Pushing the bus!
    Ashlem, alanclarkeau and Trollbait like this.
  5. GasperG
    GasperG Senior Member
    1,168
    597
    Slovenia
    2018 Prius
    Ashlem and telmo744 like this.
  6. royrose
    royrose Senior Member
    1,389
    948
    Foot of Pikes Peak
    "With more powerful motor-generators, a newly developed high-capacity Lithium-Ion battery and a booster converter, the 2021 RAV4 Prime yields an 83-horsepower (hp) jump in total system output over the RAV4 Hybrid and has the most horsepower in its segment."
    What is a booster converter?
  7. Tideland Prius
    16,070
    Impressive stats. I mean, I’d say it’ll sell like hot cakes but the current RAV4 Hybrid already sells like hot cakes. This will sell like a fire sale. L
    dig4dirt and alanclarkeau like this.
  8. alanclarkeau
    7,041
    7,580
    Yep - still a long waiting list on what is our top Hybrid model here (Cruiser).
    Tideland Prius likes this.
  9. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    Los Angeles Auto Show: Toyota touts RAV4 Prime plug-in SUV
    Ummm.
    Tesla Model X with its range of 328 miles would like to dispute that claim. It is definitely a Plug-in SUV.
    Model X | Tesla
  10. GasperG
    1,168
    597
    Slovenia
    2018 Prius
    Prodigyplace likes this.
  11. Salamander_King
    Salamander_King Senior Member
    10,964
    8,840
    New England
    Wow! RAV4 PRIME. I am trying not to read the article. So tempting...
    Tideland Prius and dig4dirt like this.
  12. hill
    8,069
    39 ev miles .... nice! That range bests the plug-in pacifica's range by about 5 miles - tho it's not going to have as much seating & cargo capacity. Still, that's great!. That pretty much begs for an increase in prius Prime's range around the same release date.
    AND ... logic dictates that the increased range /traction pack capacity means that the RAV4 will likely get the full tax incentive credit! I look forward to reading its towing capacity & hearing what the mileage is, both charged sustain mode as well as MPGe.
    vvillovv and austingreen like this.
  13. Ronald Doles
    Ronald Doles Active Member
    230
    280
    Columbus, OH
    2015 Prius v wagon
    The hybrid motor/generators output voltage is a function of rpm. The faster the vehicle travels, the faster the motor generator (MG2) rotates and the higher the A.C. output voltage and frequency.
    The first function of the inverter is to take whatever A.C. voltage/frequency is being output and convert it to D.C. which it stores in some internal capacitors. The second function of the inverter is to take the D.C. energy from those capacitors and raise (boost) the voltage to a level that would charge the batteries.
    The output power to the battery will always be less than the input power from the generator with the losses being in heat generated in the alternator and inverter which is why the inverter has it's own cooling system.
    The prime battery pack may be a higher voltage than the 201 volts of the Prius so it would have to raise (boost) the voltage to the appropriate charging value.
    #73 Ronald Doles, Nov 20, 2019
  14. Zythryn
    6,171
    4,163
    This looks fantastic!
    I hope they are widely available.
  15. GasperG
    1,168
    597
    Slovenia
    2018 Prius
    Europe for sure, because there is also press release on Toyota EU site:
    Toyota reveals the Top of RAV4 range, the new RAV4 Plug-in Hybrid
    Just like Prius it wont be named Prime, but Plug-in Hybrid
    If you add up 90 MPGe (38 kWh/100 mi) and 39 miles range, we get ~15 kWh battery. If they will use the same cells as Prius Prime then we are looking at around 120 kW power in EV mode.
    #75 GasperG, Nov 20, 2019
  16. hill
    8,069
    you have to also allow for upper & lower end buffers. You can't simply deplete and charge to the extreme ends without causing premature capacity loss. Therefore total capacity will necessarily have to be 17-18kWh. That amount also allows for maximum US federal tax credits.
  17. Lee Jay
    Lee Jay Senior Member
    5,850
    4,018
    Westminster, Colorado
    If it only had a third row, I'd be on it.
    I wonder what it's total combined range is. I can't find a fuel tank size.
  18. GasperG
    1,168
    597
    Slovenia
    2018 Prius
    Yes Of course, Pacifica gets 32 miles with 41 kWh/mi with 16 kWh battery
    So around 18 kWh and 15 kWh Net capacity
    Wonder how much tow rating will be on this thing, from technical point of view (upscaled electric motors and power electronics) it should be higher than normal Hybrid version.
  19. Leadfoot J. McCoalroller
    6,824
    6,473
    Pennsylvania
    2018 Prius c
    Remember, towing isn't what you can pull. It's what you can stop. Since the regenerative braking cannot be counted on at all times, the hydraulic service brakes usually need to be upgraded to support higher towing capacity.
  20. austingreen
    austingreen Senior Member
    13,533
    4,063
    Austin, TX, USA
    ;-) It should be if they design for it. Should be fairly straight forward but it will cost more than not designing for it. The curb weight is going to be higher and towing needs more power to the rear wheels so it would need an upgraded rear motor/power electronics and upgraded braking compared to the current rav4 hybrid to get more than the current 1750 lb rating. Doing these things will enhance awd and stopping distance even when not towing so its probably worth it, but toyota may consider anything at 1500 lbs or above good enough for a vehicle like the rav 4.
    If they price it right not only will toyota sell more rav4s (there current best seller in north america) but also upsell many buyers to the phev version.
Thread Status:
