New 12v Battery and some other bits?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rikabi, Nov 20, 2019.
  1. Rikabi
    Rikabi New Member
    United Kingdom
    Active
    Hi guys,
    any guidance on the following would be appreciated. So I have 2007 Prius with 100K Miles on the clock.
    Every so often the car refuses to go to "READY". I did a bit of digging I believe this is due the 12v battery.
    on the internal hidden menu it reads 9.6v etc when on ACC mode. When the car is running its 14v. So time for a new battery 12v?
    2nd issue I have is to with ABS/VCS (!) light coming up only when i get to speeds of 66mph. I checked on techstream on the live data and it shows the front near side sensor lags behind the other speed sensor in term of picking the speeds. Is this a case of getting a new sensor or perhaps cleaning it?
    Thanks
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yes and yes.
    Your battery is definitely worn out. It's amazing that it starts up at all.
    But wait with the wheel sensor until after the new battery is in place for a couple of days.
    I would suggest checking the connector at the wheel sensor first too.
    Rikabi and dig4dirt like this.
  3. Rikabi
    Rikabi New Member
    United Kingdom
    Active
    Any recommendation on which 12v battery I should get?
  4. bisco
    52,640
    oem is fine, but so are aftermarket. i believe @Britprius recommends exide
    are all four tires the same brand and model?
    Rikabi likes this.
  5. Rikabi
    Rikabi New Member
    United Kingdom
    Active
    Yes they are.
  6. Rikabi
    Rikabi New Member
    United Kingdom
    Active
    Anyone know a good retailer I can buy from UK? any links?
    #6 Rikabi, Nov 23, 2019
  7. bisco
    52,640
    euro car parts?
    Rikabi likes this.
  8. Rikabi
    Rikabi New Member
    United Kingdom
    Active
    They only have lion agm. Are Varta batteries any good?
  9. Mendel Leisk
    42,119
    Have you checked with the dealership, what they have, and price?
    Rikabi likes this.
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    Who is "they" ?
    And Lithium Ion is not the same as AGM.
    Rikabi likes this.
  11. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    Good catch. Silly me thought that "lion" must be some English battery brand, since he's from the UK.
    I agree on the general points above. The 12V battery is toast (well, unless there is a problem with clamps, cables, etc.). And it would not be a surprise if replacing that makes other problems go away, so replace that first before worrying too much about other issues. Then worry about the other issues.
    Rikabi likes this.
  12. Rikabi
    Rikabi New Member
    United Kingdom
    Active
  13. Rikabi
    Rikabi New Member
    United Kingdom
    Active
    Their line is always engaged and they haven't replied to a email i sent weeks back. Besides the local stealer will charge a fortune for this.
  14. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Rikabi likes this.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Lion is a brand name.
    If there's a Toyota dealer nearby, I'd check there first. Really good batteries. But most any auto parts store should have something for the Prius.
    Rikabi likes this.
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    Well I guess it IS a brand of battery.
    Sometimes things ARE what they appear. :D
    Any AGM battery of the right physical size and with the right posts should be fine.
    Don't think we have too many owners here in the UK.
  17. Mendel Leisk
    42,119
    Try dropping in? They can't all hide under the counters, lol. You're probably right, it'll be a fool's mission, but who knows.
    Rikabi likes this.
  18. Rikabi
    Rikabi New Member
    United Kingdom
    Active
    Just found out the battery was changed 1 year ago at a dealer by previous owner. I spoke to the dealer they said it comes with 3 warranty so as long it within warranty i might be able claim against them and get it done free!
    I find it odd the battery is dying already though...
    dig4dirt and Mendel Leisk like this.
  19. Mendel Leisk
    42,119
    What's your use of the car like? is it driven daily, or at least several times weekly, and how many miles, what kind of trips?
    Do you sometimes sit in the car in "accessory" mode, listening to the radio for protracted time?
    Any "incidents", door left ajar overnight, stuff like that?
  20. Rikabi
    Rikabi New Member
    United Kingdom
    Active
    My wifes car not driven much at all. Maybe 300 miles a month but driven on most days. We never used acc mode but I think we had some incidents were the kids have left the internal lights on in the back. The battery died again today after i checked the battery to see what type it was. Maybe a back hatch issue? But i always make sure no lights are on.
