"camper mode" UK spec cars
Discussion in 'Gen 4 Prius Main Forum' started by ensoruk, Nov 20, 2019.
  1. ensoruk
    ensoruk Junior Member
    43
    22
    UK
    2019 Prius
    Excel
    I can't seem to get my UK Spec 2019 Prius into "camper mode" i.e. Hybrid system running, but DRLs off.
    My Headlight switch is type B, with only 3 positions Auto/Side/Headlight. I don't have an "O" off position.
    I've tried the procedure in the manual,
    "To make your vehicle more visible to other drivers during daytime driving, the daytime running lights turn on automatically whenever the hybrid system is started and the parking brake is released with the headlight switch in AUTO the or "O" position. Daytime running lights are not designed for use at night. "
    so... I do this....
    1.car off, switch in AUTO, parking brake on.
    2. start the hybrid system (foot brake and Power button)
    and the lights come on straight away (either DRL if daylight, or headlights if night-time)
    Am I doing something wrong? or is this a config item?
    Phil
  2. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    I'll give it a go in the morning - I've done it some how - regularly if I leave it parked for a short time and locked with the real key and ON - to keep the A/C on.
  3. alanclarkeau
    7,041
    7,580
    1. Turn car OFF;
    2. ParkBrake ON;
    3. Lights on AUTO if not already;
    4. Start normally; and
    5. Enjoy camping.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    With the Hybrid system on, the headlights will come on when it's dark as we have no "Off" position on the switch here in the UK, not really any use for camping. However, on my 2016, during daylight, the DRLs don't come on when the car is started in P, but come on as soon as you shift into D or R and stay on until you switch the car off (or put the headlights on) even if you shift back to P.
    alanclarkeau likes this.
  5. alanclarkeau
    7,041
    7,580
    Yes, you have to do it in the sequence in my post #3.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Do you mean camp with the headlights on ?
  7. GasperG
    GasperG Senior Member
    1,168
    597
    Slovenia
    2018 Prius
    Interesting, will test this "park brake ON" thing, this can come in handy.
  8. alanclarkeau
    7,041
    7,580
    no - no lights came on with the sequence I used. I do it often - I'd lock Mum in the car when she said "you go in to the Post Office (et al) and leave me here with the A/C on". Or on a hot day, if I've got a short shopping expedition and I'd like to come back to a cool car.
  9. BPC Auto
    BPC Auto New Member
    Three Touring
    Germany has they hitch in the back for towing if you want to order OEM one. They also have the colored version of the large17' rim. The inserts come in blue, red, and dark sliver.
  10. ensoruk
    43
    22
    UK
    2019 Prius
    Excel
    So, I can get this to work in daylight hours... But not in the dark.... Yet
  11. Harters
    Harters Active Member
    335
    424
    UK
    Excel
    Same here, not that I go camping, but intrigued to see if it works and no matter what combination I use, the headlamps still come on.
  12. alanclarkeau
    7,041
    7,580
    Hmmm - odd that it worked during daylight.
    I just went out and tried it, and you're right.
    But I tried it in position "O" and it worked.
    Try this:
    1. Turn car OFF;
    2. ParkBrake ON;
    3. Lights on "O" if not already;
    5. Enjoy camping.
    Harters and krmcg like this.
  13. Harters
    335
    424
    UK
    Excel
    Ah, that must be the key thing, in the UK we do not have a 0 position, just Auto, Sidelights and Headlights.
    I can stop the running lights coming on in the daytime by making sure the foot break is applied, but if I try the same thing at night time then the headlamps come straight on.
  14. GasperG
    1,168
    597
    Slovenia
    2018 Prius
    Same here, no 0 position. Maybe you can trick the sensor with a light, so the car "thinks" it's day.
    kithmo and alanclarkeau like this.
