Stupid Question here......
Discussion in 'Gen 2 Prius Audio and Electronics' started by streyle, Aug 5, 2004.
  1. streyle
    streyle New Member
    47
    Germantown MD
    is there any way to get the audio info to stay on the screen? It will always default back to the energy screen for me.....
  2. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    There is a selection on the display set up screen. I think by default it is set to go back after a period of time. You can select the other option and it won't toggle.
  3. streyle
    streyle New Member
    47
    Germantown MD
    i don't see any options for this....byt the way, i don't have the GPS either.....
    this is starting to frustrate me a little...
  4. mboileau
    mboileau New Member
    278
    SF Bay Area
    The option is there on all MFD's, not just the NAV versions. It's either under the Display option or the Menu option. I found it in the Enterprise base model rental I had.
  5. tms13
    tms13 Member
    174
    Lochcarron, UK
    Business Ed. Plus
    IIRC, it's under INFO, then Settings. I'll go out and check when it stops raining.
  6. streyle
    streyle New Member
    47
    Germantown MD
    thanks! got it working!
  7. Batavier
    Batavier Member
    442
    The Netherlands
    Priuschat.com to the rescue! Points for all good answers! :D
