What kind of grease do I need for the CV axle?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SB6, Nov 30, 2019.
  1. SB6
    SB6 Member
    317
    69
    While I was replacing my right-side lower control arm, the CV axle shaft popped out and a lot of grease came out with it. A couple friends were helping me, and we managed to put the CV axle back in. I think I should add grease, but have no idea what I need to buy
  2. The Critic
    The Critic Resident Critic
    3,193
    2,322
    CA
    A little secret about doing any suspension work (especially struts or control arms): unstake and remove the axle nut, then push in the axle. This way, you will not accidentally pull it apart.
    I would just buy an inner cv boot replacement kit from Toyota. It will include a new boot, clamp and grease. If the boot came apart you will need a new clamp anyway.
    SB6 and Raytheeagle like this.
  3. The Critic
    3,193
    2,322
    CA
    Part #04437-47033, about $40.
  4. SB6
    SB6 Member
    317
    69
    My friends who were helping me seem to think that I should replace the entire CV axle. They thought that the axle shouldn't have came out so easily. However, I looked up the 1A Auto video on the replacement, and it seems to me that by design, the axle comes out that easily on this car. What do you think?
  5. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
  6. The Critic
    3,193
    2,322
    CA
    They come out fairly easily.
    The aftermarket axles are very poor quality, all of them. I would rebuild the original axle if at all possible.
    SB6 likes this.
