Apple Carplay for my 2013 Prius v
Discussion in 'Prius v Audio and Electronics' started by jackmilas, Sep 23, 2019.
  1. jackmilas
    jackmilas Junior Member
    60
    Wrocław, Poland
    Car Radio Model 57010.
    I will be replacing it with an Apple Carplay compatible radio.
    Since this is a regular car audio unit without any silly JBL "upgrade" amp (sounds much better than my 9 speaker JBL unit in Prius gen2) I understand a new radio will be more or less plug and play, am I correct? Only steering wheel interface adapter will be needed to retain buttons on the steering wheel.
  2. Joele3
    Joele3 Active Member
    133
    197
    Bay Area
    I just installed a new head. I went with Maestro RR and the harness required to use it Maestro TO2. I went with Kenwood DMX7706S. I wanted to be able to use gauges from the head unit.All steering wheel controls and OEM back up camera retained. I can finally hear some serious action coming from the rear speakers now. I did replace all speakers. All the cables from head unit are plug n play except the back up camera connector had to be spliced. Really happy with the stereo.
  3. avania
    avania New Member
    new jersey
    2013 Prius v wagon
    Just curious, where you able to get your head unit replaced ?
    Do you mind sharing some details or pictures on what head unit you have updated it to?
  4. jackmilas
    60
    Wrocław, Poland
    Could you point me in the right direction regarding the backup camera?
    I will be installing the new radio soon.
    I'm waiting for the dash kit and SWC box to arrive from USA.
  5. jackmilas
    60
    Wrocław, Poland
    Almost everything arrived.
    I just need to find the information how to get the factory camera working.
