touch-up paint
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ChipperYoung, Dec 14, 2019.
  1. ChipperYoung
    ChipperYoung New Member
    Mesa, AZ
    Does anyone know where to buy exterior touch-up paint for my red Prius? It would be to touch up some minor Chip's on the hood.
  2. Mendel Leisk
    38,981
    Dealership parts department is easiest/fastest, maybe not cheapest. Up here they have a pen-style, with clear coat at one end and colour the other end. Typical use, I take off the colour coat cap, depress the nylon nib against the top of the cap a few times till the paint starts to percolate up, then dab it on. For small/critical touch up, you could transfer the paint on the nib to a toothpick or similar. I used the clear coat end a few times and found it was lifting paint, so mostly avoid it, or only use it, ie: not over touch up paint, just clear coat.
    I've also picked up Dupli-Color, which has a brush applicator, clear coat (never use) and a nifty abrasive pen tip, that's good for prep.
    The paint code is on the decal in the driver's door.
  3. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    ...or go to automotivetouchup.com for everything you need, plus instructions.
  4. jbcarey
    jbcarey Junior Member
    45
    Poughquag, NY
    I have been using Paint scratch.com . Their dispenser is much better than the dealer "pen version" and they offer spray cans also
  5. Mendel Leisk
    38,981
    I find both brush and pen have their strengths. I like the pen better for curb rash on the rims, which with the silver rims seems to always be Classic Silver Metallic (1F7).
