EV & HV Driving Costs the Same?
Discussion in 'Prime Fuel Economy & EV Range' started by Chazman62, Dec 13, 2019.
  1. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    This is just an "approximate" calculation to compare the driving cost in each mode
    Pure HV Mode
    $3.5/Gallon
    60 Miles/Gallon
    $ per mile = 3.5/60 = $0.06/mile or $6 for 100 miles.
    Pure EV Mode
    $0.20/kWh
    25 miles using about 7 KWh (which is about 80% of the total capacity of 8.8 kWh traction battery)
    $ per mile = (0.2/25) x 7= $0.06/mile or $6 for 100 miles
    There are many parameters that are constantly changing and would affect the outcome.
  2. Tideland Prius
    16,549
  3. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Yeah, very close but at that rate of gas and electricity, EV is still slightly better. It is known that at the wall by OEM L1 takes ~6.5kWh to do 0 to 100% full charge. Using EPA standard 54mpg and 25miles EV range, or from most reported cases of PRIME efficiency, your EV range is about 1/2 of distance the car can drive with 1 gallon of gas.
    In my case the EV range in summer increase to 35 miles, but so does mpg on HV to ~70mpg. During winter EV range is down to 22 miles but so does mpg to ~44mpg. Use this 1/2 gallon HV distance for a full EV range rule,
    If you multiply the cost of electricity $0.20/kWh x 6.5 kWh= $1.30
    If a gallon of gas is $3.50 (meaning $1.75 for a half gallon distance), then you are better off with EV economically.
    #3 Salamander_King, Dec 13, 2019
  4. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    For me, here in Austin TX, the numbers work out to about 4c per mile on gas (in town; more like 5c/mile on the highway) vs. 2.5c/mile charged from home.
    Austin Energy also has a program where (speaking in round numbers), for a $1/week, you can charge all you want around town, which thankfully includes my place of work.
    For me, miles driven that way come out to around 0.5c/mile.
    Arguably though, what’s even more valuable here is that I’m putting hardly any wear on my ICE, so at age 58 now, there’s a fair chance *I* will expire before our Prius Prime does!
    #4 mr88cet, Dec 13, 2019
  5. bisco
    51,851
    about equal for me in the pip as well, but ev is funner
    vvillovv and benagi like this.
  6. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    My electricity ~$0.12/kWh and my car has cost me on average about $0.031/mi in fuel (electricity/gas).
  7. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    5 cents per key at home here in Reno. So around penny per mile.
    vvillovv likes this.
  8. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    You are spending only about 1/2 of what I'm spending here in SoCal - $0.06/ mile is fuel whether electric or gas...
