tow eye
Discussion in 'Gen 2 Prius Main Forum' started by harper42, Oct 1, 2006.
  1. harper42
    harper42 Member
    226
    Here I go again, asking something that might be somewhere in the manual. If that upsets you, please ignore this question
    The Tow Eye on the side of the front bumper: What is it for? Husband asked me, and I don't know. I know what it's called, from this forum, but how it would be used in towing, I don't know. Thanks to those of you kind enough to answer.
  2. Sufferin' Prius Envy
    3,998
    In the trunk with the spare tire stuff is the tow ring itself.
    Pop off the tow ring bumper hole cover, thread tow ring in place, tow car.
    P.S. You may want to crack open the Owners Manual for more specifics so you don't damage your car.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    To expand a bit...it is for serious emergencies only...dragging the car out of a deep ditch when a proper tow truck can't be found/used, etc. it is NOT for routine towing as in a breakdown or flat tire or whatever.
  4. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(efusco @ Oct 1 2006, 12:20 PM) [snapback]326524[/snapback]</div>
    It also works great for the extreme emergency of carrying a kayak on the roof. Tie off the bow to the tow eye for a very clean setup (you don't need to drag the line over your bumper and hook to the loops under the car).
    donbright likes this.
  5. jamarimutt
    jamarimutt New Member
    985
    You asked for it, you got it... RTFM. :D
  6. slothfratelli
    slothfratelli Junior Member
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Oct 1 2006, 03:11 PM) [snapback]326522[/snapback]</div>
    Has anyone not been able to pop off their tow ring cover? Suggestions?
  7. TheForce
    3,461
    537
    Wheelersburg, Ohio
    <div class='quotetop'>QUOTE(slothfratelli @ May 5 2007, 07:53 PM) [snapback]436189[/snapback]</div>
    A small knife or screwdriver will work. A small suction cup will work also.
  8. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(slothfratelli @ May 5 2007, 04:53 PM) [snapback]436189[/snapback]</div>
    I admit that it is a booger! Actually, it is easy to pop off. It is hard not to ding up the surrounding plastic! Next time I have it off, I'm going to put a little handle on the dang thing!
  9. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Use the edge/corner of a thin credit card to pry it out. Plastic is less likely to damage your bumper. I used my library card.
  10. abador
    abador New Member
    Michigan
    I was able to get the cover off by going through the car wash. They never did call me to say they found it. :p
