Gen3 engine replacement with Gen4
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SteveLee, Dec 25, 2019.
  1. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    My son just pulled his 2012 Prius engine (blown head gasket for about a year so it was a mess) out the top and leaving the trans in place. Has now set in a 2017 replacement purchased from across the country. Still in the process of connecting everything in his spare time but wow, I am very proud of him since he had little mechanic experience. But he was motivated, being a poor college student, and refused to give up on his Prius. He used the Youtube series on replacing the Prius engine for direction. Just wanted to mention it here to encourage others.
    RMB, tvpierce, Mendel Leisk and 5 others like this.
  2. chronon
    chronon Active Member
    601
    106
    here and there aint be in frozen wasteland no mo..
    i did an engine replacement with help of fam, alot of help from a few online people on here, some utube and the manual - i want to tell u he told me dont pay antention to the toy tech manual, they will have u do stupid things like take the dash out , essentially they have u spending twice as much time as u need to to do get the job done - this was an 05 , i think an 06 engine replaced it , we spent about 80 manhrs , about 2 weeks total working about every day , quotes from mechanics were around $1000 on up , and most mechanics simply didnt want to fool with high V, for fear of electrocution and perhaps from not being trained/qualified in the new tech -
    SteveLee likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Hope it’s possible with a 2017 engine
    SteveLee and TheeWood like this.
  4. bisco
    51,155
    how many miles on her?
  5. chronon
    601
    106
    should be with same generation, if your puling a bigger engine out 6of a newer gen car to put into an older gen car,
    there could be issues ..
  6. SteveLee
    645
    180
    North Carolina
    I
    His has 180k. The donor engine has about 40k
  7. SteveLee
    645
    180
    North Carolina
    I
    So do we. Based on the video series it works, though there are some relatively minor alterations like changing the motor mount to the old one, and a few others. The motor mount was one of the few things not covered in the video and became apparent in the installation. But it was a direct bolt-on replacement. So far, so good.
  8. SteveLee
    645
    180
    North Carolina
    I
    BTW, the dealer wanted $7,000 to replace the engine.
    chronon and bisco like this.
  9. bisco
    51,155
  10. bisco
    51,155
    what is the history? has he owned it since new? ever clean the egr?
  11. SteveLee
    645
    180
    North Carolina
    I
    Edited History: He bought the car with about 130k miles on it. About 160k it started making "noises", like misfiring or a cylinder not firing, running very rough. At first, it was for very short periods but got increasingly worse over the next months, more often and for longer periods. He did finally learn how to remove and clean the egr cooler and valve. But by that time I think the damage was done, he was losing coolant. By this time he had replaced the water pump which may have been the cause of overheating and blowing the head gasket. He also replaced the plugs and coils, hoping they may be the issue. But the symptoms just continued getting worse until it finally wouldn't run. That's when he had to do something next level.
    #11 SteveLee, Dec 26, 2019
  12. Mendel Leisk
    40,584
  13. SteveLee
    645
    180
    North Carolina
    I
    Yes, that was for a new Gen3 engine. I think it was a price stating they did not want to do it, but if you insist this is what it will cost you. The used donor engine with about 40k miles was about $1,100 with shipping from CA to NC.
    Edit: The used replacement engine also came with the intake manifold which may have to be replaced with the old one. Not sure at this point.
    #13 SteveLee, Dec 26, 2019
  14. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    When he pulled the water pump, did he investigate it:whistle:?
    I’ve seen a couple of pumps show signs of failing (I’ve examined 4 of them), and the impeller seems to begin rubbing on the containment shell:cool:.
    That extra resistance can cause the rpms to not be right, leading to other unintended consequences ;).
    If he still has it, try to spin it by hand and inspect the impeller:).
    Curious minds would like to know if the specimen is available(y) .
  15. SteveLee
    645
    180
    North Carolina
    I
    Yes, exactly. That is what we noticed when we compared the old one with the new one. The impeller did not turn as freely, there was some friction resistance when turning it by hand. I understand this is not an uncommon finding when there has been a blown head gasket. There was never any indicator on the dash of overheating but at some point he told me the temp sensor wire had been disconnected. I hate to think the previous owner or dealer would have disconnected that to avoid replacing the pump. That would have been a relatively easy fix to prevent ruining the engine. The difference between a few hundred and multiple thousands of dollars.
    tankyuong and Mendel Leisk like this.
  16. SteveLee
    645
    180
    North Carolina
    I
    A little help here. Since the flywheel and damper of the Gen4 engine has to be replaced with that of the Gen3 engine, what if any significance is the arrow on the flywheel?
    Edit: Any suggestions on a free service manual?
    #16 SteveLee, Dec 31, 2019
    SFO and Mendel Leisk like this.
  17. seeker311
    seeker311 Junior Member
    43
    17
    Austin, TX
    Howdy. I am literally at this step. Swapping the flywheels / dampers and already removed them without marking them as ragingfit video suggests. I don't see any obvious alignment identifiers except the arrow on the flywheel. the damper doesn't seem to have alignment marks either. Both parts are just spinning in a circle so I wouldn't think there are any required alignment marks for timing, etc. actually that is a false statement. there are timing marks, but i believe they are on the crack shaft pully, so we should be good. I'm going to try and remember how they were and keep them together and fingers crossed, because if there are required marks, it's gonna suck to remove the engine and realign, unless it can be done without separation.
