Running rough with 2 bars on hybrid battery in slow traffic
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jeff C 2010, Dec 26, 2019.
  1. Jeff C 2010
    Jeff C 2010 Junior Member
    Good afternoon everyone!
    I have a problem with my 2010 Gen 3 that I need help identifying the cause. I have searched for the answer but have not found it yet.
    The other day while on my way home I was stuck in holiday traffic. As usual the battery was being drained slowly and after about 10 minutes of heavy traffic the ICE started when the battery was at 2 bars. While the engine is recharging the hybrid battery if I tried to move forward with traffic the engine seemed like it was about to die and throw up a piston. It would jerk and vibrate like an out of balance clothes washer in spin cycle and make a sound like a the squawk of a large bird. But this would only happen if I accelerated slowly. If I were to accelerate at a normal pace the engine would perform fine. I am worried that I may be damaging something.
    I find myself completely confused as to what is happening. The system knows the battery is low and is recharging it so why would it act up when I try to move up slowly? This will only happen when the battery is at 2 bars and the engine is having to charge the battery and power the vehicle. Once the battery gets to three or four bars it operates as normal.
    Any advise or links to other threads about this will be most appreciated!
    Thanks,
    Jeff
    52,354
    how many miles on her?
    have you cleaned the egr circuit?
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    When HV bat soc is below 40%, or on the bottom end of the 2nd bar, ICE kicks in to charge. When ICE comes on for that situation, it's louder and higher RPMs to charge the HV battery quicky back to 50%. This is the EGR is giving you an indication that it's clogged enough to knock the entire ICE. Options- You either drive it until it knocks like crazy and break down, or save up & replace ICE soon, or clean the EGR circuit soon as you can. I like option #3, had it done to mine and it will save you time, frustration & money in the future.
  4. Jeff C 2010
    Cleaned the egr tube and manifold about 10000 miles ago. Cleaned cooler 50,000 miles ago. I’ll do it again or may just replace it this time.
    Mileage is 280,000 and climbing.
    RMB likes this.
  5. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Spark plugs and coolant level?
  6. Mendel Leisk
    41,865
    That's pretty commendable. Yeah get on the EGR complete cleaning again. How was the EGR pipe when you cleaned it, 10K back?
  7. Jeff C 2010
    Light dusting only. Manifold was dirty.
