Can i install an android head unit?
Discussion in 'Gen 3 Prius Audio and Electronics' started by newpriusowner2011, Dec 21, 2019.
  1. newpriusowner2011
    newpriusowner2011 New Member
    canada
    Hi I'm wondering if I can install a touchscreen android head unit to my base model 2011 Prius (no screen/gps etc)
    Just wondering if a base model has all the necessary feeds to power an Android head unit.
    I would like Bluetooth, google maps, music player.
  2. TheeWood
    TheeWood Junior Member
    24
    Orlando, FL
    I got one for Christmas that I plan to install in the next few days (maybe today?). Will let you know how it goes. The answer should be yes.
  3. TheeWood
    24
    Orlando, FL
  4. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I agree with TheeWood. Click on the link he shared and you should see everything you need to make the install work. It seems that the most important thing is getting all the correct cables and adapters to make the reverse screen and steering wheel buttons work.
    TheeWood likes this.
  5. travisjb
    travisjb Junior Member
    NC
    I installed one today and having two issues... RCA output doesn't work and not getting signal to sub / amp. Steering wheel controls not working - not sure how to diagnose this... I suspect I did something wrong in wiring?
    Also, there were a couple unused wiring dongles in the car that I have no idea what they do Lol. One is probably satellite radio... not sure about the other, maybe OEM camera?
  6. TheeWood
    24
    Orlando, FL
    I just finished my install. Was very simple and looks great. Basically plug and play with the model I got.
  7. travisjb
    NC
    Did you have to do anything in particular to get steering wheel controls working? I know in some cars you have to either hold down VOL UP key or repeatedly press same key with a new system to get the controls to re-initialize... mine are simply not showing up in the Android "Wheelkey Studio" app.
  8. travisjb
    NC
    This is just a blank / filler post so I can reach min threshold to share response
  9. wsalopek
    wsalopek Junior Member
    70
    Morro Bay, CA
    2015 Prius Plug-in
    Which brand/model is that head unit? And did/do you have JBL or non-JBL? Thanks...
  10. TheeWood
    24
    Orlando, FL
  11. travisjb
    NC
  12. rosner
    rosner Junior Member
    Israel
    Hey Theewood, How do you like this headunit of Sinosmart? How is the startup time? how is the software?
    I am a bit worried that it doesn't have a physical volume knob. This may be a safety issue (finding the volume up/down keys on a flat screen without looking away from the road). Unless I use the steering wheel controls (which I don't do often today).
  13. Karolis
    Karolis Junior Member
    Vilnius, LTU
    Sinosmart Android 8.1 Car for Toyota Prius 2009 2010 2011 2012 2013 GPS Navigation Radio 2din 2.5D IPS/QLED Screen-in Car Multimedia Player from Automobiles & Motorcycles on AliExpress
    I've also ordered this particular model, should receive in a couple of weeks.
    My Prius is a 2015 Five with JBL. I've ordered canbus adapter, which, according to seller, should take care of the amplifier and the factory backup camera.
    I have my doubts about that. Factory camera needs 6V input, not 12V right? I don't see any voltage converter in the harness photos.
    Also, instead of 10 + 6 pin audio connectors I have a 20 pin connector (the one on the left in the photo)
    Looks like I'll have to troubleshoot as I go with this one.
  14. TheeWood
    24
    Orlando, FL
    The startup time is not an issue at all. The software isn't great and the screen mirror software that comes with it doesn't work but looks awful if it did work anyway.
    The lack of a volume knob took a bit to get used to and the backlight on the volume keys aren't great but it also has a volume button on screen that is easy to use and see. It's definitely not as plug and play as I thought it was going to be. I need to take some time to figure out how to get some things working or working better than they currently are such as radio reception and steering wheel controls.
  15. TheeWood
    24
    Orlando, FL
    I just wanted to follow up on this and say my unit didn't last long once late spring in Florida came. I think the heat did it in. The screen mostly shows black and white lines now.
  16. plainv70
    plainv70 Junior Member
    Naperville
    2024 Prius
    Is your car garaged or outside?
  17. TheeWood
    24
    Orlando, FL
    It's outside. Newer car is in the garage.
