Dead battery twice in two weeks.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jeff68005, Jan 1, 2020.
  1. Jeff68005
    Jeff68005 Junior Member
    Metro Omaha, Nebraska
    I have had to call AAA twice in two weeks for a totally dead battery (no panel lights until AAA hooks up). I tried a lithium 8k starter without success and returned it. I went from 0 v to 3.x volts at best. Car made a sound when at 3.x v. I have been blessed not to be locked out since the car is in the garage, I do not lock it.
    When AAA comes, I have to keep their starter system hooked on for a long moment until the engine powers up, then good to go.
    Questions: (I know economic value of my 2010 Prius is only about $4000.00, but I have not seen any car that I like enough to replace the car.) Nothing newer has rear glass like it to see who/what wants to craw into my backside when driving.
    When driving, my battery indicator varies from full down to 2 bars and builds back up. Depending on traffic, my build back up without going all the way down.
    Dealer will replace the battery for under $200, but I have some other concerns.
    What is the normal Amp hour rating of a standard 12v replacement hybrid battery? Are better rated replacement batteries sold? Will they be recharged like the standard battery? How much driving is needed to recharge the battery? Must I stop and go or will driving it 30+ miles at about 45-50 MPH in power mode do the job?
    I am convinced something is draining the battery when start/turn off button is set to off in the garage. I am habitually good about turning off interior lights, headlights or parking lights Intermittently, I have the interior lights set not to light up when the door is opened.
    Sometimes, I get a low key fob message. Will shut down not complete when that happens? (I have now replaced both fob batteries after second AAA jump start.)
    When using the key fob to unlock the door or hatchback, is it possible a solenoid is still draining the battery?
    I am at the point that despite the cost, I would like to modify my 2010 Prius with a method of maintenance charging the battery system similar to the later models that plug into a 110v (USA) setup. I am convinced not driving the Prius for several days may be my culprit as well since I retired and don't drive much sometime for days at a time.
    TIA for any discussion.
    #1 Jeff68005, Jan 1, 2020
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    How old is the current 12 volt battery?
    If you check the jump point under the hood in the morning after the car has been off all night, what does the voltage read?
    Replacing the 12 volt isn’t that hard, and Auto Zone or the like have deals on the batteries.
    Just make sure the battery has the vent port;).
    Good luck and happy new year(y).
    Grit and Mendel Leisk like this.
  3. Jeff68005
    Thank you. Car is usually ok unless, I fail to run it for a few days or a week. Current battery was dealer replaced a couple of years ago. It seems to be ok or totally dead. I do not perceive behavior in between those events.
    Some of my errands like McDonald's is only about 3-4 miles each way. Sometimes, I go in and restart the car when returning. Sometimes, I use drive thru and only start the car at home.
    When driving, I seldom drive in Power mode.
    #3 Jeff68005, Jan 1, 2020
    Raytheeagle likes this.
  4. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    After you replace the 12V battery, get a CTek 3300 (link here to Amzn, but you may find it cheaper if you look around, just make sure it's the 3300 model for US). This is a 'smart' charger, which means it monitors what it's doing and stops charging when done, then holds the charge as needed, so it can be left attached to the battery indefinitely. It comes with a nice pigtail which you can attach to the battery terminals in the back--as I have mine--or to the jump points under the hood. I just fished the pigtail up into the cargo area from below on extreme right rear. No need to disconnect the battery for charging, and it even has a cold weather setting. Excellent product; I'm in a similar situation to yours, days go by between driving episodes.
    Note: I use a good outdoor extension cable for connecting, and there is enough leeway at the rear hatch seal to allow the CTek cable to extend outside the car and still fully close the hatch (gently).
    #4 Ed Beaty, Jan 1, 2020
  5. Jeff68005
    Interesting. The one I tried was BEATIT B10 QDSP 800A Peak 12V Portable Car Lithium Jump Starter (up to 7.2L Gas or 5.5L Diesel Engine) Battery Booster Phone Charger Power Pack with Intelligent Jumper Cables From dead battery, my car took this one down inside a minute with maximum car 3.x volts.
    #5 Jeff68005, Jan 1, 2020
  6. Ed Beaty
    334
    311
    Salt Lake City
    The one you tried is NOT a battery maintainer, which is what I'm talking about. It will keep your (new) battery healthy, NOT jump start the car. Please reread my post....
  7. Jeff68005
    Understood. and I read the Amazon info which offers 4 versions of that brand.
  8. Mendel Leisk
    41,640
    That's a fair deal.
    Ok, that's not so good. If you're using the car as a daily driver, doing at least 10 miles a day regularly (say 5 or 6 days a week), it should last at least 4~5 years. If it's often shorter trips, and the car regularly sits for multiple days, then you should start thinking about an automatic charger, something along the lines that @Ed Beaty describes.
    That's pretty much exactly my situation and solution, except that I'm using the CTEK 4.3. I have a 3.3, that was my go-to charger for years. Keep it in the car as a spare now. I used the supplied quick-connect wire, which is handy if you're going to be hooking up regularly. I connected at the under-the-hood fuse box positive terminal, which is a little tricky to access. See @NutzAboutBolts video #23 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    You connect the quick-connect's positive lead there, and the negative to grounded bare metal. I went with one of the bolts on the Inverter coolant reservoir's support bracket IIRC, because it was right there.
    When connecting, always make the connection to wall current last, and disconnect it first. And keep an eye on the status lights. And read the manual, lol.
    Also, I found it was really tight fit installing the positive lead, needed to strip the (mostly ornamental) plastic shoulder insulation off the pigtail connector, and bend it (carefully) through a right angle, in order to get it fitted and the cover back on.
    I left the (capped) quick-connect laying loose in that corner. When I need to use it I pop the hood, connect to the charger, then lower the hood gently, on the wire, just ajar, not fullly closed. This works for in a secure garage, for me.
    For outdoor use, you might want to consider running the connector out through the grill. I have a concern with an install like that though: seems like someone could short out your battery if they had a mind to. Best to keep such an install well hidden.
    Well, New Year's Day, more'n likely an idle day, I'll go out to the garage and plug it in.
    Done. Once plugged in thus, it will run through a charging cycle (takes maybe 4~6 hours), and you can just leave it thus till the next time you need to use the car. There's no danger of overcharging: it runs through a charging cycle (read the manual, to determine optimum schedule, there are options), then subsides to sporadic trickle charging.
    #8 Mendel Leisk, Jan 1, 2020
  9. Jeff68005
    Quote: That's pretty much exactly my situation and solution, except that I'm using the CTEK 4.3. I have a 3.3, that was my go-to charger for years. Keep it in the car as a spare now. I used the supplied with that quick-connect, which is handy if you're going to be hooking up regularly.
    Why do you use the model CTEK 4.3. you chose instead of the a CTek 3300 ?
  10. Mendel Leisk
    41,640
    There's nothing wrong with the CTEK 3300; it actually offers virtually the same functionality as the the 4.3. Common story for me: I'll buy stuff for my son, and it's "Ah Dad, I'm never going to use this; You keep it."
    Which is mainly why I have the 4.3. The one extra it has is the ability to do a desulphate cycle, if I'm not mistaken. I don't believe the 3300 has that. I've used that once, but normally just use regular automotive charging cycle, and since I have an Optima Yellow Top, I follow the manual recommendation and use the the "snowflake" option, which is slightly higher charging voltage IIRC.
    But yeah either is good. The 3300 is 3.3 amps, and the 4.3 is (you guessed it) 4.3 amps. I'd suspect the 4.3 gets through the charge cycle faster, but doesn't seem to be a lot of difference.
    Jeff68005 likes this.
  11. fmerkel
    fmerkel Member
    88
    46
    Seattle, WA
    IMO that lithium jumper should have worked. I have one. I have not tried it on a Prius, have not needed to. I have used it on a 4-cyl Honda with the battery entirely disconnected and it started the car. I've also used it on a Toyota Highlander with a dead battery and it started it right up.
    Strongly suspect your current 12v is shot. Likely has a shorted cell. When the rest are fully charged it....barely.....starts the car. When it sits too long the voltage plummets until it no longer has enough to work. This is typical behavior for a dying battery.
    With your driving habits I also recommend a battery maintainer. Seems a number of EV and Hybrid cars are poor at taking good care of the 12v system. I use on on my Nissan Leaf regularly.
  12. Jeff68005
    Not sure what I am doing just yet, but I ordered the
    CTEK (56-958) MUS 4.3 POLAR 12 Volt Fully Automatic Extreme Climate 8 Step Battery Charger from Amazon. Thanks all for the conversations.
    dig4dirt and Mendel Leisk like this.
  13. Ed Beaty
    334
    311
    Salt Lake City
    Erratum: Looking more closely, it appears that I have the CTEK MUS 4.3 as well. Somehow, I got '3300' stuck in my head (I blame Leisk....). At any rate, it's a great piece of gear and works well (is working right this very minute, in fact).
    Jeff68005, dig4dirt and Mendel Leisk like this.
  14. fmerkel
    fmerkel Member
    88
    46
    Seattle, WA
    If you don't have one it's also worth picking up a digital voltmeter. If you have Harborfreight near they are pretty cheap. You don't need to spend a lot on this as measuring 12v Pb is not delicate electronic work. You simply want to see it over 12v for sure. At 12v it's actually getting a bit dicey. It's best if it's something like 12.5-14v. My 4 year old battery shows ~13.5v after a fresh topping charge.
  15. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    What is your tank-ly MPGs?
  16. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I’m curious... I’ve had the same 12V battery in my car since new; April 2012. Granted, I don’t have cold winter weather. When the battery dies, I’ll replace it. But why the rush to get a battery maintainer? Original battery lasts five or six years without a maintained so the replacement should as well... unless you don’t drive the car often, etc.
    #16 Rebound, Jan 1, 2020
    Raytheeagle, The Electric Me and Grit like this.
  17. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Agree. Most 12V car batteries life span are 3 to 5 years w/o maintenance if vehicle recharging system is working properly. If you're in need of constant recharge with car off, you either are experiencing parasitic drain or battery needs to be replaced. Once you buy a new battery that holds charge up to 12.7v, there's no need to buy charge unit unless you drive it once every 2 weeks.
    #17 Grit, Jan 1, 2020
    J1050 likes this.
  18. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Hmm..I'm curious about this as well..
    Seems to me the first step would be to replace the 12 volt. Then in the future if you want to go the battery maintainer route, it always exists.
    But if the 12 volt is failing, it just needs to be replaced.
    As far as could something be draining it?
    I kind of doubt it.
    It really could be as simple as the 12 volt is old, and needs to be replaced.
    Just seems the steps are out of place.
    First I'd determine the state of the 12 volt battery in the vehicle. Replace as necessary. Then going forward I might..just might worry about getting a battery maintenance system in place.
    But if the 12 volt is healthy, new, and there isn't any peripheral issue, you should be fine with a new 12 volt.
    IF there is some peripheral issue draining the battery, then a battery maintainer would only be masking the real problem.
  19. Mendel Leisk
    41,640
    "peripheral issues" tend to rear their head when the car is driven infrequently, and short distances. There's always a slightly background draw on the battery. With steady, moderate use, the battery will be ok. Otherwise, I think you do need to consider preemptive strategies, to wit: regular hook up to a charger.
    Ed Beaty likes this.
  20. Ed Beaty
    334
    311
    Salt Lake City
    It must be remembered, in the context of all the above excellent advice, that the OP's (@Jeff68005) central point was that he does not drive his Prius very often.
    Jeff68005 and Rebound like this.
