How to Change Your Transmission Fluid
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Triparadox, Aug 4, 2019.
  1. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    You’ll get it done in an hour next time, now that you know how.
    Bbonez and Mendel Leisk like this.
  2. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    At our SF meet ups, we get 3 people on the task. Got both my engine oil and ATF changed within one hour, we got our own NASCAR pit crew.
    RMB, Bbonez, Triparadox and 1 other person like this.
  3. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    spec is 3.6 quart, so sounds perfect.
    Congrats on the completion!
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    You need a helmet to protect your hair:p.
    Maybe we should have those for next time;).
    Although ATF-WS hair gel is an interesting look(y).
    RMB, Grit, jerrymildred and 1 other person like this.
  5. Mendel Leisk
    41,645
    And used a 3/8" Allen key, not 10 mm. :mad:
    dig4dirt likes this.
  6. Triparadox
    Triparadox Active Member
    201
    108
    Agree 100%. When wiping off the excess dripping, my hair actually got into the drain bucket.
    RMB and Raytheeagle like this.
  7. ASRDogman
    ASRDogman Senior Member
    7,651
    3,939
    I'm glad you were successful! Stuff like that is a royal pain!
    But now you know it's done correctly and will be easier the next time.
    It took me just over an hour to change the oil and trans fluid, from jacking up the Prius to
    lowering it down and putting everything away. It's pretty easy.
    And I wasn't rushing. Depending on how many miles you drive its a once a year or 2 thing to do.
    My Snap On 10 mm hex fit perfectly. Mendel used a 3/8 one. I guess it depends on which
    brand you use. But if yours is a little loose, you can use the valve grinding compound to tighten it up.
    But if you didn't over tighten either plug, they will be easy to remove next time. :)
    Triparadox likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,153
    Tampa, FL
    Yippee!!!
    Yeah, I agree with the others. Next time should be about an hour. It takes longer to get the car up on the jack stands than anything else. LOL!
    Also, next time, I recommend not plugging the fill hole. You'll know right away when it's full and the only spillage you'll have is what's in the hose. And you can pour faster since the air escapes faster. Just pour in the first 3+ quarts as fast as the hose will take it. Then slow down as you get closer to full. It'll still make a bit of a mess, but not as much.
  9. Mendel Leisk
    41,645
    No, I used a 10 mm bit. Using a 3/8" bit, maybe just a funky 3/8" L-shaped Allen key on a cheater pipe, is likely what rounded the drain bolt socket.
    3/8" = 9.525 mm
    Use a long-handled ratchet wrench too, no drama. And torque to spec: 29 ft/lb.
    #169 Mendel Leisk, Jan 4, 2020
  10. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    No way!!! I should have brought a wig that time so it would be like a glove, oil gets on the outside and when done, just remove it :LOL:
  11. ASRDogman
    7,651
    3,939
    Okay, I just re-read your post. I miss read it. sorry... :(
  12. Triparadox
    201
    108
    I'll keep the pipe in mind. At first I was just afraid if the fluid will leak out as soon as I pour it. That's the main reason why I decided to use some sort of channel to make sure they fit perfectly. Anyway, I saved about $15 from buying a pump.
  13. Triparadox
    201
    108
    Ok! Next time I'll try without the metal pipe connector.
    jerrymildred likes this.
  14. jerrymildred
    11,517
    14,153
    Tampa, FL
    If I understood your description correctly, there wasn't any way for you to know when the transaxle was full since the fill hole was closed off. If you guess really well, no problem, but you might guess poorly and have quite a bit come out when you pull out the filler. Or nothing comes out and you have to put it back in and add more. Letting the oil spill out the spill hole tells you right away that it's full. ;)
  15. Mendel Leisk
    41,645
    One thing that sends me into a slow burn, just a little venting:
    I think Toyota should be obligated to publish basic maintenance instructions, in the Owner's Manual. The engine oil and filter change, and the transaxle fluid change.
    Of course, they'd have to acknowledge the need for a transaxle fluid change first I suppose.
    And not just the cryptic Repair Manual format instruction: a step-by-step, common sense, complete how-to.
    Also, change the 10 mm hex pocket in the fill and drain bolts, to a 3/8" square pocket, so any 3/8" drive ratchet will work, as-is.
    Grit likes this.
  16. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Whose going to even read the manual? The posts here are proven facts that no one reads it :ROFLMAO:
    elementnomore and Mendel Leisk like this.
  17. ASRDogman
    7,651
    3,939
    Why would any manufacturer make it easy for anyone other then their people to work on their car?
    They would be bitting themselves in the foot.
    They ALL want you to come to them for everything. They don't want you to work on your own car.
    Or any other mechanic/technician for that matter.
    I don't blame them for that. They have invested the time and money into developing their product.
    Why would they make it easy for someone else to copy it and/or take advantage of their hard work?
    Butttt...... I personally think that the first manufacturer that makes a car that is EASY to work on,
    inexpensive to work on, and that's dependable and reliable, and inexpensive, replacement parts
    would be prices near to the aftermarket parts, they would sell millions!!!!
    So far, the Prius fits some of those things, for me.
    #177 ASRDogman, Jan 5, 2020
    jerrymildred and Ed Beaty like this.
  18. Mendel Leisk
    41,645
    86 Honda Accord Owner's Manual pics. There's more too, wiper refill replacement (even that's not in the Prius manual), spark plug replacement, fuel filter, air filter. Anyway:
    IMG_1783.JPG IMG_1784.JPG IMG_1785.JPG IMG_1786.JPG IMG_1787.JPG IMG_1788.JPG
    #178 Mendel Leisk, Jan 5, 2020
    Grit likes this.
  19. MSF1344
    MSF1344 Junior Member
    61
    UK
    Active
    It is very quick and easy job if you have a correct tools and car stands for leveling . I did mine in 30 mins and the gearbox now happy with new oil .☺
  20. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Great upload, detailed instructions for diy. But we’re so busy with smartphones, social media and Netflix that this info would be wasteful on paper because we’ll eventually hire out the service maintenance.
