EV mileage
Discussion in 'Prime Main Forum (2017-2022)' started by ed4271, Jul 17, 2019.
  1. Salamander_King
    Salamander_King Senior Member
    10,963
    8,839
    New England
    It all depends on the gas price and electric rate you are paying. For me a full EV range is almost always about half gallon HV mileage no matter what season. During summer, I get 35 EV miles, but my HV mileage is almost as high as 70mpg. During winter, my EV range diminishes to ~22miles, but so does HV mileage down to 44mpg.
    What is your electric rate and gas price? In my location, electric rate of $0.19/kWh and gas price of $2.40/gal, it has been cheaper to drive HV for most part of my PRIME ownership. Currently the break even point for the gas price is $2.50/gal.
    #101 Salamander_King, Dec 10, 2019
  2. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Definitely something going on. It's called colder weather. Actually, depending on your speeds and the temperature, 25 miles might be really good. With the electricity prices some you you north easterners are saddled with, the only advantage I can see to the Prime would be hedging your bets against future gas prices.
    Even here in sunny FL, I can see a huge difference in EV efficiency between the driving I did Sunday and what I did today. Sunday was 37 miles and I had 4.6 m/kWh. All in EV thanks to being able to charge at both ends. Today, so far, has been 42 miles and I have 5.4 m/kWh so far. All in EV again. The difference was the speeds of the roads I traveled. Temperatures were about the same.
  3. john1701a
    john1701a Prius Guru
    12,747
    5,243
    57
    Didn't you purchase your Prime to also make other people better off? There's a very real benefit from using less gas and emitting fewer emissions, even if you can't equate it to a monetary value. You'd be amazed how much your small contribution to a larger cause really adds up.
    #103 john1701a, Dec 10, 2019
    D.A.L, jerrymildred and Dael like this.
  4. vvillovv
    vvillovv Senior Member
    3,529
    1,241
    NY
    Gotta remember those 28 charging sessions are being done as outside temps drop. If you got the car in may of june instead of late fall, you'd see some difference in your EV range.
    But if 25 miles of EV range is not good enough for you in this weather, there is nothing wrong with driving in HV all the time. The car will adjust and give you the best it's got.
    jerrymildred and Salamander_King like this.
  5. jerrymildred
    11,491
    14,100
    Tampa, FL
    And that's better than anything else on the road that I can think of!!
  6. bresna
    bresna Active Member
    193
    144
    Southern Maine
    Other than the fact that I live down in York and commute 63 miles each way to Chelmsford, MA for work, we have just about the same numbers for break even.
    Again, this will be my 3rd winter with this Prime (>80,000 miles now), so I know that my EV range will go down. It's just that it's never gone down this much before. It could just be the tires. All of my Toyota Hybrids have reduced efficiency in the winter, be it from the cold temps or the crappy winter gas.
    I have continued to charge up and trying to maximize my E miles, but it is mainly to save money. The green aspect of it is a nice bonus but let's be real - me burning a 1/2 gallon less gas per day is not that big of a deal when I'm literally being surrounded by more & more gas-guzzling SUVs every day.
  7. vvillovv
    3,529
    1,241
    NY
    Yep, it's the sad truth. Whatever I do myself to protect the future of humanity is severely overshadowed by a million others only caring about getting ahead of me in line,
    Dael and benagi like this.
  8. bresna
    193
    144
    Southern Maine
    As I updated in another thread, my EV range has gone down again. Now, it's only showing me to have 22 miles of EV range. I think it's time to stop wasting my time & money plugging it in until it warms up again.
    Dael likes this.
  9. Salamander_King
    10,963
    8,839
    New England
    My GOM is currently showing 47.7 miles on a full charge (a value without Climate Control). It is not 47.7 miles of pure EV range on my daily drive. Rather it is with a mixed HV mode to supply needed heat. In reality, I am driving ~20 miles (out of ~36 miles driven) on EV mode using ~50% of battery charge (~3.2kWh) daily. My historical winter months (Dec-Feb) mpg (mixed EV and HV drives) for the first two winters were 68 mpg average with a range of lo 50.9 to hi 95.6. My last month (Dec) average mpg (mixed EV and HV drives) was 76.8 mpg, which makes current strategy to show the ~13% improvement from previous two winters average.
  10. Dael
    Dael Member
    128
    32
    Ohio
    2020 Prius Prime
    ours has always been about that but we have always gotten on freeway which burns it up right quick.
    It has shown some improvement of late with short local trips.
