White Paint Issues
Discussion in 'Prius v Main Forum' started by mikefocke, Sep 10, 2019.
  1. mikefocke
    4,039
    1,835
    Sanford, NC
    Received a letter from Toyota yesterday for my wife's '11 Avalon Blizzard White saying they were aware of some paint peeling issues with the BW and the White paints parked in the sun for extended periods and were coming up with a corporate approach to the issue. So if you have or had problems, document them thoroughly and wait for them to document the way they wamt you to handle it.
    I post this in the v section since many early v wagons had BW paint and may be subject to the issue.
    I will also say my family has or had 4 BW Toyota products with no such issues. Only one was regularly parked outside.
  2. Air_Boss
    Air_Boss Senior Member
    4,222
    1,188
    New Yawk
    No issues with 1G3 Winter Gray Metallic in the sunshine
  3. Bumble
    Bumble New Member
    Tampa
    The Blizzard Pearl problem do affect Prius but Toyota currently is excluding us from the support program. I know because My car was affected if it is a Corolla or Camry, yes they fix it. Prius then no.
