2008 Toyota Prius- Brakes don’t work...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Emiley Juarez, Jan 11, 2020.
  1. Emiley Juarez
    Emiley Juarez New Member
    Mississippi
    The ABS and brake lights are on but that wasn’t what really scared me. I was reversing and I pressed on the brakes to stop. It made a high-pitched beep noise and it didn’t stop, I kept pressing on the brakes and the car finally stopped abruptly after three-five seconds of pressing on the brakes. This has happened 3 times to me while reversing. I don’t know much about Prius’s and this has never happened to me. If anybody has ever experienced this or has any knowledge, that would be greatly appreciated !
    51,843
    welcome!
    most likely the master cylinder. how many miles on her? any dash lights?
  3. Emiley Juarez
    Mississippi
    Thank you ! 148k miles And just the ABS and emergency brake lights.
  4. PriusCamper
    PriusCamper Senior Member
    12,688
    5,134
    Pacific Northwest, USA
    The error codes related to those warning lights will tell you specific details about what needs fixing...
    valde3 likes this.
  5. Kaptainkid1
    Kaptainkid1 Active Member
    308
    246
    Los Angeles
    You obviously have a problem with the brakes I would take it to a mechanic and have the car looked over. Prius has a normal brake system and any mechanic can look it over.
    SM-J737T1 ?
  6. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    Not necessarily. It could be a problem with hydraulic system. Which is why starting by reading fault codes would be the best option.
