Bunch of codes bunch of problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Timothy Jones, Jan 12, 2020.
  1. Timothy Jones
    Timothy Jones New Member
    Georgia
    Have a 2008 prius, 130k mi
    Codes pulled at auto zone:
    P1121 coolant control valve(just replaced a month ago and it came back)
    P1122 & p1123
    Accelerator full close switch short & open
    Not finding much info on this? Main symptom is a number of warning lights (red triangle, vsc, brake) and after about 45mins driving the engine shuts off. Restarting the car resets it temorarily.
    Not HV battery, already been through that.
    P093A
    Inverter coolant system issue
    I replaced the inverter coolant pump a month ago to prevent this but alas it coded...
    CEL also on.
    I will likely replace coolant valve and pump again but I’m stumped on the accelerator issue. Maybe a Throttle Position Sensor? Or new pedal? Any ideas?
  2. George W
    George W Active Member
    909
    510
    San Antonio
    Have you tried running Torque Pro on your smartphone with an OBD2 code reader?
    Did the auto parts place clear the current codes out, to see if these same codes duplicate?
  3. Timothy Jones
    Georgia
    No and no, however the only code I had before is 1121, the rest are new codes, and considering the issues I’m experiencing, something IS wrong. Just not sure what to fix
  4. Elektroingenieur
    2,515
    3,253
    Three Touring
    On Prius cars, diagnostic trouble codes (DTCs) P1122 and P1123 have nothing to do with the accelerator. DTCs that begin with P1 and certain other prefixes (see my previous posting) are defined in the SAE J2012 standard as “manufacturer controlled,” and their meanings are not standardized. I imagine “Accelerator full close switch short & open” applies to some other vehicle.
    More importantly, don’t rely on the one-line “fortune cookie” (@ChapmanF's apt term) descriptions; the malfunction might not be in the part named there. I’d suggest using the step-by-step troubleshooting procedure in the Repair Manual (more info) for your car for DTCs P1122, Coolant Flow Control Valve Position Sensor Circuit Low, and P1123, Coolant Flow Control Valve Position Sensor Circuit High.
    DTC P093A isn’t listed in the Repair Manual; did you mean P0A93, Inverter Cooling System Performance?
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Throttle body code may be because the throttle body has never been cleaned or lubricated and the butterfly is not moving smoothly.
    The other issues may be you did not get all the air out of the systems.
    George W likes this.
  6. Timothy Jones
    Georgia
    replaced coolant control valve and inverter pump. still have codes P1122 & p1123, I cleared them and they came back the next day.
    also now my heater blows ice cold air... seems it may be a clogged A/C coolant pump? anyone know where that is?
  7. Timothy Jones
    Georgia
    Yes, sorry, I replaced inverter coolant pump and that is fixed, just have p1122 and 1123 left now
  8. dolj
    dolj Senior Member
    7,447
    3,751
    Wellington, New Zealand
    • P1122: Coolant flow control valve (water valve) position sensor circuit range check (low voltage)
    • P1123: Coolant flow control valve (water valve) position sensor circuit range check (high voltage)
    Although each DTC title says "Coolant Flow Control Valve", these DTCs are related to the water valve.
    DTC Trouble Areas
    1 P1122
    • The water valve (Coolant flow control valve)
    • Short in WBAD (valve position signal) circuit S Open in VC circuit
    • ECM
    2 P1123
    • Open in E2 circuit
    • VC and WBAD circuits are short-circuited
    • Open in WBAD circuit
    • ECM
    Read freeze frame data using Techstream (or another capable scan tool). Freeze frame data records the engine condition when the malfunction is detected. When troubleshooting, freeze frame data can help determine
    • If the vehicle was running or stopped,
    • if the engine was warmed up or not,
    • if the air-fuel ratio was lean or rich, and
    • other data from the time the malfunction occurred.
    Here is the full diagnostic procedure for these two codes (three actually P1120 is there too.):
    DTC P1122 | Coolant Flow Control Valve Position Sensor Circuit Low
    DTC P1123 | Coolant Flow Control Valve Position Sensor Circuit High
    Wasn't aware of an A/C coolant pump.
    #8 dolj, Jan 29, 2020
  9. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    Did you try the add two hose on the two coolant bleeders to the top coolant tank to bleed the air out of the system? You said you have no heat
  10. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
  11. ChapmanF
    14,974
    I'd say that looks like a Gen 2 Prius with a pair of clear hoses on it, one from the engine coolant bleeder on the radiator, the other from the inverter coolant bleeder on the front of the inverter, both running back into the inverter coolant reservoir, with a funnel stuck in the engine coolant filler neck, and the cap still on the engine coolant recovery bottle.
    m.wynn likes this.
