Need to know how to get to Air Vents..
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sheila'sprius, Sep 20, 2006.
  1. sheila'sprius
    sheila'sprius New Member
    Hi...
    I have a dead mouse in the front of my car somewhere.... I am kind of a do-it yourselfer so I was wondering how hard it is to take the dash apart..?.. The dealer wants $120/hour to look for it... I'm obviously a cheap butt or I wouldn't drive a car that gets 50 MPG..
    Has anyone dove into the dash yet?.. Any help would be awesome..... : :
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
  3. dreichla
    dreichla New Member
    2,230
    Connecticut
    I've taken my dash apart a couple of times to install Coastal Electronics stuff. Coastal Dave's got great color installation instructions that include the dash dismantle process.
    It's not difficult.
    Maybe someone has access to the instructions which could be scanned into a PDF. If not, I'll try to find the documentation and post it here for you.
    You know - that mouse will stop smelling at some point if you just leave it alone.
    edit -
    Ok I posted a little late - the instructions above are pretty much the same as Dave's - maybe a bit more comprehensive. I'd use those.
  4. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    Are you sure it's a dead mouse? If not positive, before you start tearing things apart you may want to try other methods to get rid of the smell. i.e. spraying lysol (or some other mold killer) in the air intake.
  5. sheila'sprius
    <div class='quotetop'>QUOTE(San_Carlos_Jeff @ Sep 20 2006, 12:55 PM) [snapback]322347[/snapback]</div>
    oh yeah.... I've had poop and then babies in the back with the spare tire...
    <div class='quotetop'>QUOTE(theforce @ Sep 20 2006, 12:45 PM) [snapback]322338[/snapback]</div>
    THANK YOU SO MUCH.... I GUESS I COULD LEAVE HIM IN THERE TILL THE SMELL GOES AWAY.. BUT THAT'S GROSS.........................
    <div class='quotetop'>QUOTE(dreichla @ Sep 20 2006, 12:50 PM) [snapback]322341[/snapback]</div>
    I REALIZE IT WILL QUIT SMELLING.... BUT IT'S JUST GROSS..... THANKS FOR THE HELP!!
  6. sheila&#39;sprius
    sheila&#39;sprius New Member
    <div class='quotetop'>QUOTE(sheila'sprius @ Sep 20 2006, 12:41 PM) [snapback]322332[/snapback]</div>
    I have used your instructions... Dash is apart... Found the dang dead mouse in the Cabin Air Filter BOX part..... Any idea how to get into there?
  7. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    <div class='quotetop'>QUOTE(sheila'sprius @ Sep 20 2006, 09:15 PM) [snapback]322596[/snapback]</div>
    However it did get in it must have been a one way street. :blink:
  8. TucsonPrius
    TucsonPrius Member
    167
    Tucson, AZ
    2020 Prius
    <div class='quotetop'>QUOTE(jburns @ Sep 20 2006, 09:08 PM) [snapback]322624[/snapback]</div>
    Or a dead end.
    Sorry, couldn't resist.
    Shawn
  9. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    95
    Indiana and Nevada
    As colder weather approaches, so does the mice...found one this morning lying in the cabin filter, stinking up the car after eating my poison in the garage...it was trying to make a nest on the filter...so we tossed him and had to get a new cabin filter...so if your cabin stinks ,look at the cabin filter a i bet it will be there...
  10. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    They come right in through the intake opening under the cowl, which
    is easily accessible [by a small critter] up through the fenders and
    then into the area behind the cowl. Same path water takes to get
    out. Then they can hop right into the A/C intake, slide down and
    land either on the filter, or if they eat their way through that,
    into the fan. That's pretty much the end of the line, since the
    fan blades are fairly fine-pitch and the space around them is small.
    I've heard that making sure to go into "recirc" mode before shutdown
    will close the flap against outside access, but I haven't completely
    checked out the topology. I think some outside air can *still* come
    in in recirc mode, just not sure how [or if it's mouse-sized].
    The other thing to be aware of is the engine air filter -- it's warm
    after you arrive, even in a Prius that's EVed its way in the last
    half mile. I installed a little piece of 1/4" mesh over the airbox
    inlet, as I've done in two previous cars too out of necessity. If
    you find bits of acorns and junk in the bottom of your airbox, it's
    time to do something. They can find the stock intake opening and
    waltz right through the resonator and feed pipe, and love that long,
    dark, *warm* cave.
    _H*
  11. druid
    druid Junior Member
    San Francisco Bay Area
    Thanks for all this info. I'm having a recurring problem with mice and it's starting to worry me -- not only is the smell gross, but they carry the hantavirus, which is transmitted to humans by inhaling atomized mouse droppings and urine. What could be better for spreading such a disease than the ventilation system of a car?
    According to the web pages I read, the virus can lead to a pulmonary syndrome in humans that was first recognized in the early 90's. At that time it had an 80% fatality rate, partly because nobody knew quite what it was. With good treatment there's now about a 70% chance of survival. But that means there's a 30% chance of buying the farm just from inhaling some mouse dust. I see a big potential liability here for car manufacturers who fail to take reasonable steps to mouse-proof their products. There haven't been many cases of this syndrome yet in the U.S. -- a few hundred I think -- but it would be pretty damned easy for Toyota to put screens over the entry points people are describing.
    Meanwhile, the less mechanically inclined among us (such as me) would appreciate more advice on how to retro-mouseproof. Hobbit, how did you attach the mesh (and what kind of mesh did you use)?
