How to install JDM cruise control switch ?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by MSF1344, Jan 17, 2020.
  1. MSF1344
    MSF1344 Junior Member
    61
    UK
    Active
    My prius gen 3 is imported from japan and it is not comes with CC , I bought a aftermarket one but dont know is it plug and play or need a wire to connect to ECU ? Thanks
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    It is not just a switch.
    Contact the people that you bought the cruise control from for help installing.
    If they don't speak English, you probably are screwed.
  3. Mendel Leisk
    38,241
    Two new threads and 6 or 7 threads "revived", that should do, lol.
    Grit likes this.
  4. MSF1344
    61
    UK
    Active
    What you mean two new threads and 6 ,7 ?
  5. Mendel Leisk
    38,241
    Look in "new posts". You have so many different threads going, on same question. No worries, it'll settle down. :)
    Grit likes this.
  6. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    Nothing wrong being a member of tv show “The View” :D
  7. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    What about “Engrish”?
  8. Tideland Prius
    16,072
    Basically you did a shotgun approach which is poor forum etiquette. I'm going to leave this one and delete the other posts you have.
    Ok you also did that with the reverse camera.
    Please do refrain from posting across multiple threads in the future. Answers get lost and people don't want to reply to multiple threads to the same question as it's not good use of their time.
    #8 Tideland Prius, Jan 19, 2020
  9. StevieIreland
    StevieIreland Junior Member
    Scotland
