Prius 20099 problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priuslover09, Jan 9, 2020.
  1. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I think around 2,279$ There cheaper then Toyota here’s the website Crownsville Automotive - Crownsville, MD.
  2. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I thinking about taking my 2009 Prius there to get regenerative breaking fix the thing that charges the battery and the radio fix the radio sound is low even though the it’s on the max sound and oil change
  3. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I still need the p0000 code gone on my friends Prius 09 any thoughts it’s a fault code
  4. bisco
    48,947
    aftermarket scan tools
  5. bisco
    48,947
    how many miles on her? that's a lot of repair work. my 08 at 140k has had nothing but regular maintenance
  6. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
  7. bisco
    48,947
  8. dolj
    dolj Senior Member
    7,487
    3,763
    Wellington, New Zealand
    Perhaps I should have said, "Just FYI P0000 is not a valid Prius or Toyota Techstream code." You still didn't answer the question, "with what are you reading the codes?"
    So, it took that guy (whose credentials were not stated, so just some guy on the internet) 4:34 to say that P0000 is an SAE standard code that means there are no codes at this time.
    .... or is it? Given the above definition, if you accept it, why are you so fixated on clearing it, given that it is not really there in the first place. It is just the way the tool you are using has to say, "you do not have any faults codes at this time."
    Techstream does not display P0000 if there are no codes, it simply displays no codes if there are no codes. I know which one is more logical – to me at least.
    SFO likes this.
  9. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I’m reading the p0000 code
  10. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    Sounds like a novella :love:
    bisco and Raytheeagle like this.
  11. dolj
    dolj Senior Member
    7,487
    3,763
    Ok. Let us know when you resolve this fault.
  12. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Ok I have been able to erase it it hasn’t came back on as of now.
  13. bisco
    48,947
  14. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I made a new theard just now.
  15. bisco
    48,947
    well done
  16. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Thanks
  17. bisco
    48,947
    pleasure
  18. dolj
    dolj Senior Member
    7,487
    3,763
    If you would care to share how you were able to erase the P0000, it would be so much help to the rest of us, so we can help the next person with this problem.
    :)(y)
    SFO likes this.
  19. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I disconnected the 12v for 10 minutes and it Erased the code.
  20. dolj
    dolj Senior Member
    7,487
    3,763
    Thanks for that, it is good information. It is interesting how you couldn't clear it with your code reader.
    One last question, when you only had the P0000, were there any lights on the dash, or not?
    #60 dolj, Jan 20, 2020
