PP 2017 battery degradation?
Discussion in 'Prime Main Forum (2017-2022)' started by Rieuk, Jan 4, 2020.
  1. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    Ignore what I said...
  2. Trollbait
    11,328
    No, your original comment was about PHEVs having better resale because they have an engine and work as a plain hybrid. Not sure what exactly you were counting as an "early-generation EV", but the fast depreciation on many of them was due to incentives on new. The only EV that seems to be holding value isn't a PHEV; 5 year old(early gen) Model S have a depreciation rate similar to Toyota hybrids, The Hybrids and Electric Vehicles With the Lowest Depreciation. It seems too early to call if a PHEV will hold value better because of the engine.
    Used PiP list for about the same price as higher trim Prii of the same age and mileage. The original MSRP difference was about equal to the incentives available at the time. Toyota plug ins sold in the next two years will very likely get the full federal credit, and then it it will be another year of reduced credit value. Then there is state incentives and manufacturing incentives to compensate for those.The effect of incentives on their plug ins resale value isn't going away soon.
    Really? Dealers didn't want to deal with plug ins because of the limited scope of incentives, and not because they were a risk to their main income stream, the service department?
  3. john1701a
    12,749
    5,243
    57
    You know. It's the entire "EV Market" up until December 31, 2019. Not a single vehicle with a plug competed directly with traditional choices yet, because the qualification had not been met. Its price must not be subsidized. To deliver sustainable profit, it must be able to stand on its own. Looking at how that is achieved, we see 2 obvious examples:
    Tesla is striving to achieve high-volume sales without the generous $7,500 tax-credit and an early-adopter audience now faced with many choices. The gigafactory efforts combined with migration to Model 3 are big steps toward the goal, but it has only been 11 days since phaseout of the federal subsidy. Delivery of enough profit to everything necessary to sustain the business remains a challenge, without any clear path or timeline. Mainstream buyers are far more difficult to appeal to than early-adopters.
    Toyota is demonstrating they are already well on their way to high-volume profitable sales with a plug, looking well past their phaseout of tax-credits. Evidence of that is undeniable. Their largest production plant in the world (over 9 million square-feet, with 8,000 full-time employees) has added RAV4 hybrid to what they produce. It's in Georgetown, Kentucky, making it an ideal location to capitalize on PHEV opportunity. Adding a plug to the hybrid is an option showroom-shoppers will naturally be drawn to.
    Both examples look beyond the "early" activity in the market still playing out, one that doesn't even adhere to a standard approach for charging yet... or with regard to the topic at hand, have any standard approach to measure or provide warranty for battery degradation.
  4. Rieuk
    Rieuk Member
    103
    53
    Pasadena
    Fair enough. I guess I'll see what happens over time. Is there a way to see the power consumption by the battery from the car dashboard, though?
  5. Chazman62
    Chazman62 Member
    108
    65
    Long Beach, CA
    2020 Prius Prime
    I'm confused...
    The battery consumes power?
  6. hill
    8,069
    i'm certain the inquiry means, "is there is a way to observe consumption of battery power energy"
    Chazman62 likes this.
  7. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    I'm not sure what you're asking either, but @hill's suggestion sounds reasonable. If so, you can set the MID to show m/kWh. That will give you a bar for every mile.
    Or you can choose to show the m/kWh for whatever trip meter you have selected.
    But there is no instantaneous indication of m/kWh like there is for mpg. I suggest reading up on the instrument cluster section of the owner's manual. It has a TON of good info.
  8. john1701a
    12,749
    5,243
    57
    Actually, there is... it's just a matter of stumbling across the many options available.
    jerrymildred likes this.
  9. jerrymildred
    11,491
    14,100
    Tampa, FL
    Duh!!! I feel like a real bonehead now. I use that all the time, but it just slipped my mind as I was writing. Thanks, John. Maybe I need a nap. :oops::sleep:
    Raytheeagle likes this.
  10. john1701a
    12,749
    5,243
    57
    A yawn is a silent scream for coffee.
    Raytheeagle and jerrymildred like this.
  11. Rieuk
    Rieuk Member
    103
    53
    Pasadena
    Hey, thanks for this! That's handy to know. I guess what I am really after is a straight number of kWh dispensed by the battery for a given trip. I suppose one could just multiply miles/kWh by the number of miles in the current trip.
    What would be better, though is if the car can display how many kWh was replenished after a given charge session. I don't want to rely on the reading at the wall (if I'm lucky enough to even have one).
  12. Salamander_King
    Salamander_King Senior Member
    10,964
    8,840
    New England
    If you use OBDII adaptor and android phone app Hybrid Assistant, you can get total kWh of battery energy used for a trip.
    Rieuk, Rob43 and jerrymildred like this.
  13. Trollbait
    11,328
    The kWh from the outlet isn't going to be the same as the kWh from the battery, because of charging and conversion inefficiencies. If you want the number to track how much electricity you are using from the grid, you want the the amount from the outlet. The EPA MPGe number is figured from the outlet.
  14. Rieuk
    Rieuk Member
    103
    53
    Pasadena
    My goal is to track the battery degradation over time. For this I want to eliminate the variability in transmission efficiencies from the wall (this varies because I don't always charge in the same place). So I don't want the wall reading, I want the reading from the car itself.
    Rob43 and Trollbait like this.
  15. bisco
    48,979
    tech stream?
  16. john1701a
    12,749
    5,243
    57
    For those of you yearning for data from more aged plug-in hybrid batteries, here's a video from of Prius PHV after 4.5 years of use (just under 81,000 miles)...
    13.9 miles of EV after all those years/miles from a vehicle with an 11-mile rating speaks for itself.
  17. jerrymildred
    11,491
    14,100
    Tampa, FL
    Nice! My PiP had almost the same time and miles when I traded it in. If I just drove on the local 35mph streets with occasional stretches of 45, I could get about 14 miles. On my miserable high speed stop and go work commute ... not so much.
    john1701a likes this.
  18. Rieuk
    Rieuk Member
    103
    53
    Pasadena
    So I was also participating in this thread here, but I'll focus my posts here since I created this thread.
    I want back to look at my Miles/kWh by month and have the below data to report. It's not looking good and this is consistent with my observations that I'm only getting a charge of 5.5 kWh these days instead of the usual 6.8 kWh. My estimated range these days is about 25 miles. I went to check my tire pressure and I have 40 PSI at the front and 39 PSI at the rear. Not sure what's going on but I'm not happy. I received the car in January 2018. This much degradation (if it is degradation) is not acceptable. Sadly I'm not sure there's anything I can do about it.
    Basically, my miles/kWh seem to be consistent, implying that the total energy capacity of my battery has reduced. Thoughts?
  19. bisco
    48,979
    yeah, seem to be a small percentage of underperformers. too bad toyota isn't willing to take a deep dive to try and figure out what the problem might be
  20. Rob43
    Rob43 Senior Member
    1,373
    1,044
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I'm very interested to see you graph the upcoming months of: May, June, July, August, & September.
    Rob43
