12v option from harbor freight? Hmmmmmmmm
Discussion in 'Gen 2 Prius Technical Discussion' started by Ianmeister, Jan 19, 2020.
  1. Ianmeister
    Ianmeister Active Member
    316
    319
    Meridian Idaho
    Ok. I think the picture speaks for itself. I wonder if there’s a member with non SKS will to try this crazy idea for a 12v battery option.....
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Terminal posts?
  3. Ianmeister
    316
    319
    Meridian Idaho
    They are square with threaded holes unlike OEM which are round posts. So some assembly is required.
  4. WilDavis
    2,493
    2,155
    49
    …isn't there something about vents/tubes too? Good price, but (as they say) the devil is in the details! ;)
  5. Ianmeister
    316
    319
    Meridian Idaho
    Yeah you’re right this one is sealed. Well, it was an idea. Not necessarily a good idea, but an idea nevertheless.
  6. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    box does say valve regulated, so not sure if you can tap into that for vent tube?
    dimensions?
    jerrymildred likes this.
  7. Ianmeister
    316
    319
    Meridian Idaho
    7 1/4 high x 8 long x 5 1/8
  8. Mendel Leisk
    41,824
    thunderbolt solar 12 volt 35 amp hour universal battery
    ^ Search string if anybody wants it. Checking the harbor freight info:
    12 Volt, 35 Amp Hour Sealed Lead Acid Battery
    against my third gen battery measurements:
    OEM battery info (measurements taken directly):
    Battery id: S46B24R GS YUASA
    length: 9 3/8" (238 mm)
    width: 4 7/8" (124 mm)
    height: 8" (203 mm) (plus posts)
    post dia's:
    Pos: 13 mm (approx)
    Neg: 10 mm (approx
    Weight: 310
    The thunderbolt varies as follows:
    Length: 8" (minus 1 3/8"
    Width: 5 1/8" (plus 1/4")
    Height: 7 1/4" (minus 3/4")
    It might work, with a 3/4" shim under. Except for the vastly different posts. That would be a deal breaker for me. I think too 35 amp hours is less, the OEM is 38 amp hours?
  9. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
  10. Ianmeister
    316
    319
    Meridian Idaho
    Isn’t there a kit to allow square posts to convert to round? Or did my brain make that up......
  11. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    lol, might have been your post that made my mind think that one too.
    I think @Mendel Leisk had some posts on that recently, but it may have been convert from american to jdm or something?
  12. Ianmeister
    316
    319
    Meridian Idaho
    My brain invents all kinds of crap that didn’t happen.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    It is a "lawn mower" battery.
    Others have used similar ones in a pinch for short terms.
  14. TinyTim
    TinyTim Active Member
    386
    236
    Seattle
    They have a good return policy and I think the standard 20% coupon could apply on this battery. You could probably make it work. The Gen 2 Prius is in their glory years. One step above a junker. With that I say go for it. When I say Junker it's like a tooling car or a kit car. At the point in its life cycle. You really can experiment a lot with your Prius. If things go sideways you can send it to the boneyard.
  15. ETC(SS)
    7,312
    FWIW?
    I don't think it's crazy, but I'd invest some of my savings in a decent jump pack and keep it ready.
    Juuust sayin
    Ianmeister, Merkey and dig4dirt like this.
  16. nssdiver
    nssdiver Me digging' life
    Syracuse, NY
    Four Touring
    That battery should be fine for an G2 SKS Prius that is driven at least a couple times/week. If you can't figure out how to connect to the terminals, though, this may not be a job for you. The venting is the only thing I'm not 100% sure about.
    FWIW - I was jumping my Prius with a Makita Drill/Driver battery for a while between when my OEM battery STB and when I got a Yellow Top (form that educational guy) with adapter kit. Can't remember if it was a 12V NiMH or 14.4V NiMH though.
    dig4dirt likes this.
  17. Landon51
    Landon51 Member
    190
    63
    US
  18. R-P
    R-P Active Member
    808
    288
    Netherlands
    I think my non-SKS is something like 38Ah originally?
    I've been running this similar replacement 55Ah for the last 3-4 years with screw terminals. And no vent tube. But neither has my Volvo's 100Ah battery in the open boot, which is a similar setup and distance from the passengers as my Prius.
    I think I would use the Harborfreight battery without any hesitation if I wasn't a stickler for battery maintenance (the biggest battery will last the longest). Price seems excellent. I can't find what I payed for mine, but it was AT LEAST 100euro (~2euro/Ah), probably 130 (~2.5euro/Ah including all taxes) or so and I searched for a long time before buying to get best value for money. So 2$/Ah seems like a steal as long as the euro is worth more than the $ (at time of writing 1EURO=1.10$) and taxes aren't >25%.
    Gratuitous pic of them side-by-side
    #18 R-P, Jan 24, 2020
  19. Ianmeister
    316
    319
    Meridian Idaho
    tax around here is a hair under 10%
  20. R-P
    R-P Active Member
    808
    288
    Netherlands
    I found my purchase price (the company has a different name since January 2016 when I ordered it... which is why I couldn't find the order in my computer).
    It equates to 2$ per Ah for the 55Ah (cheaper than I thought, but as said, I found the absolute best price I could find during at least 3 months of (occasional) searching).
    But that was 4 years ago, so this 2.2$ per Ah (incl. all tax) sounds like an excellent deal.
    #20 R-P, Jan 25, 2020
