ABS Accumulator Prius V and Regular Prius Compatibility?
Discussion in 'Prius v Technical Discussion' started by JayRock_PHX, Sep 7, 2019.
  1. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    ok so I’ve changed my fair share of Prius second gen leaking abs like some of these 2010 and now some 2012-2015 Prius.
    I have a V and Toyota dealer confirmed that the abs CSP just released does cover the Prius V at all. Pretty stupid because i have the exact issue and it’s only at 114k.
    Anyways I’m having some issues trying to find out if the standard Prius ABS Accumlator (twin round cylinder thing) will interchange with the “Prius V” specifically 2012 located below the brake abs unit that goes to your brake pedal.
    I can’t seem to get a straight answer. Previously with the gen2 I could interchange pretty much any of the years in the gen2 range but usually went for the later model to eliminate future problems.
    Has anyone changed their Prius V Accumlator pump (twin cylinder thing) I’m trying to find out if the standard Prius unit will work or do I have to get specifically the “Prius V” one. Please see the attached picture for the unit I am referring to.
  2. Tim Jones
    Tim Jones Senior Member
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    I am working on this same problem now 2013 v. Have the junkyard pump now off 2012 prius. Will have this done sometime next week.
  3. Tim Jones
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    I still haven't done the install..... But will soon. And I think this will be valuable info for v owners.
    If it doesn't work we will know. I got one off a 2012 prius 70,000 miles $90.00
  4. Tim Jones
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    Have you done anything on this... I still haven't as I have 5 vehicles...but the pump is running a lot...drove it today
  5. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    Someone else posted in a different thread that it was the same. But I been waiting for a definite answer before purchasing. I’ve already replaced the regular Prius and just the pump assembly itself I think shud fit. Meaning the two round cylinder things you see.
  6. Tim Jones
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    any update?
    Thanks
  7. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    Man I apologize. I been so busy with everything else like repairs for other people I haven’t even had a chance to jump on my own deals. Stupid question but Do you happen to have an accumulator off a Prius v? Because I have one off a regular Prius that I just replaced and have the customers busted one and we can try and compare ? Lol
  8. Tim Jones
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    Same here......I have the parts but haven't tore into it yet...
  9. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    **** I found a good deal on a real low miles unit and I really need this confirmed. **** nice person hell
  10. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    So today I had to grab that accumulator we been stressing about. I got one from a 2013 Toyota Prius according to the owner and the papers. Best thing is it’s only 42k Miles. I only got the accumulator reason being is the previous owner replaced the other half thinking that was the issue. Not once but twice!
    Anyways I shud have an answer on this tomo.
    After Each one of you that wants the answer PayPal’s me $50 per answer.
    lol I kidd I Kidd.
    M
    Tim Jones likes this.
  11. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
  12. Tim Jones
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    So it's working?
    I have the pump and master with 54,000
    Tempted to just do the pump first just to see.
    Got them off a Lexus. Have several now.
  13. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    yes it’s working. And it’s working great. My gas mileage has really shot up. Funny thing is I was getting battery issues. Actual replace hybrid battery code. But I never looked into the voltages or anything.
    And now it’s gone. And confirmed that the battery is fine as well. Weird false positive but it does make sense though.
  14. rjparker
    7,565
    4,437
    Not sure I understand how a brake accumulator could make that much difference especially on the health of the hv battery. Its not drawing much current, far less than headlights or ac. It is possible that cooler weather is making a difference especially for a car in a hot environment which degrades HV batteries faster. I would guess any battery issues may reappear especially if the 12v controls were disconnected for a period of time.
    #14 rjparker, Feb 7, 2020
  15. Tim Jones
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    My pump runs all of the time and mpg is the same.
  16. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    This new pump is barely running. It hasn’t hit even 50k and it just barely turns on. Maybe because it’s so new that it operates efficiently. Hell if I know.
    Lol I do not know why I said my gas mileage really shot up.
    I guess I meant to say with the pump operating correctly along with the battery that the mpg has shot back up to where it shud be.
  17. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    why not do it at the same time? U will have to take off the master and all that anyways to get to the pump. So might as well do it at one shot.
    the leaking accumulator does have a possibility to destroy the master too as the gases from the accumulator weaken or damage the master according to the Toyota documents for the recall/repair etc
  18. Tim Jones
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    You don't have to take the master off to change the accumulator
  19. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    for some reason I always want to call the booster assembly the “master”
    idk why. But yes u are right. My apologies.
