1. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Had an opportunity to do the 90K service on a 14 Prius v. Oil change, air filter, cabin filter, brake fluid flush, trans fluid, engine coolant, inverter coolant and tire rotation. All done in just under 2 hours. It is amazing how easy these cars are to work on and how inexpensive they can be to maintain. I think my cost on all of the parts was only ~$110.
    iPhone ? Pro
    #1 The Critic, Jan 22, 2020
    RMB, NutzAboutBolts, Grit and 5 others like this.
  2. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    (y)
    Savings over a dealer (with your labor@$50-140/hr) ....$500-800+
    Knowing it was actually done..... and done correctly.....Priceless!
    :) Sweet!...here is to another 90k miles on that Prius!
    RMB, m.wynn, ASRDogman and 2 others like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,142
    Tampa, FL
    Nice! That hoist must be a huge time saver. (y)
  4. bisco
    51,484
    is that really the 90k service?
    The Critic likes this.
  5. ETC(SS)
    7,043
  6. Rebound
    Rebound Senior Member
    3,994
    2,642
    Portland, OR
    It’s about right. I’m guessing he inspected the brake pads while he had the wheels off, maybe lubricate the sliding pins.
    The two coolants have different intervals, but may as well do them together.
  7. The Critic
    3,193
    2,330
    CA
    Depends who you talk to. For me, every 30K service gets both air filters and brake fluid. At the 90K service I service both coolant loops. Plugs get done at 120K.
    I typically service WS transmissions at 60K intervals. This one was done once at 30K, so it is receiving its second trans service at 90K.
    Not really. I could have done this on the ground in a similar timeframe, but the clean-up would have taken a lot longer.
    Raytheeagle, SFO, Grit and 2 others like this.
  8. Rebound
    3,994
    2,642
    Portland, OR
    Mike, can you tell us about the gizmo you’ve attached to the coolant reservoir?
  9. The Critic
    3,193
    2,330
    CA
    Airlift™ Kit | Cooling | UView
    It is a vacuum filler for cooling systems. It evacuates most of the air from the system prior to filling. For certain applications, it is a lifesaver.
    iPhone ? Pro
  10. Mendel Leisk
    40,919
    What's your vacuum source?
  11. Grit
    Grit Senior Member
    6,559
    4,222
    Wilkes Land
    Love the non-oem fluid theme (y)
    m.wynn and elementnomore like this.
  12. The Critic
    3,193
    2,330
    CA
    It uses shop air. The filler utilizes the venturi effect to draw a vacuum on the system.
    The "GC" coolant is made by CCI, which is the supplier of the Genuine Toyota coolant.
    Idemitsu is supposedly a supplier of WS to Toyota.
    I highly doubt that either product is 100% identical to the stuff sold under the Genuine Toyota label, but it is probably still better than using a multi-vehicle atf or an universal "all makes/models" coolant.
    m.wynn, Raytheeagle, Bbonez and 2 others like this.
  13. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,692
    1,736
    Bay Area
    Must be nice to have a personal lift :whistle::whistle:
  14. jerrymildred
    11,517
    14,142
    Tampa, FL
    I saw one in use in a video and wish I had one. So I looked it up and found it on Amazon for about $129. I might be tempted when it gets closer to time to change coolant. I have mixed feelings. Kind of dear when I think about not really NEEDING it, but liking the time savings. But compared to paying a shop, one use would pay for the purchase. Hmmmm.
  15. Mendel Leisk
    40,919
    Watching @NutzAboutBolts video, where he does the engine coolant change just running in maintenance mode and topping it up occasionally, I think it's not that hard.
    Do you have a compressor Jerry? If not, another big step.
    m.wynn and NutzAboutBolts like this.
  16. Grit
    Grit Senior Member
    6,559
    4,222
    Wilkes Land
    Compressor? Not required, not even a big step. We did both coolant change on mine at our meetups w/o one. Easy peasey.
  17. The Critic
    3,193
    2,330
    CA
    Vacuum filling the cooling system makes the outcomes more consistent by ensuring that most air is removed. Any bleeding afterwards is almost icing on the cake.
    It is not critical on the Gen3’s since they are not very problematic, but it is absolutely necessary on the Gen 2 if you are not using the bleed screws.
    iPhone ? Pro
    Raytheeagle and Grit like this.
  18. Rebound
    3,994
    2,642
    Portland, OR
    And your method lets you verify that there are no cooling system leaks.
  19. Mendel Leisk
    40,919
    Yeah I've heard that. There's a second gen engine coolant change video I've watched, and it's arduous!
    Well if you get that gizmo it's required, it needs a strong vacuum source.
    Grit and jerrymildred like this.
  20. jerrymildred
    11,517
    14,142
    Tampa, FL
    I could not imagine life without an air compressor. How do people get anything done without one?? :D
    Edit to add, that would be as bad as not having a multimeter.
