DIY Replace 3rd Gen Struts
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pk123, Oct 21, 2019.
  1. ASRDogman
    ASRDogman Senior Member
    5,893
    3,161
    Gnarly likes this.
  2. Mendel Leisk
    38,207
    I recognize those too, gave mine to one of son's friends, decades back.
    Looks like quite a job. (y)
    Gnarly likes this.
  3. Tim Jones
    Tim Jones Senior Member
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    I've done the same job. Hard to believe but the struts and shocks are different on the v.
  4. Fostel
    Fostel Member
    87
    25
    London
    Excel
    Hopefully, I have got some time for EGR yet.
    I am at 85k miles and some suspension issues and front brake job postponed so I need to focus on that first.
  5. douglasjre
    douglasjre Senior Member
    1,763
    616
    Orlando, FL
    Buying struts is not enough. You have to buy the strut socks and the sway bar links too. I highly recommend doing the front and rear at the same time
    Tim Jones and Fostel like this.
  6. douglasjre
    1,763
    616
    Orlando, FL
    Have now tried both KYB excelG and Sachs. Kyb excelG is much better
    SFO, Tim Jones and Fostel like this.
  7. douglasjre
    1,763
    616
    Orlando, FL
    Regular alignment shop doesn't need the computer. As long as they turn the car off while it's in the rack...
    Fostel likes this.
  8. ASRDogman
    5,893
    3,161
    I don't think they'll be able to turn the steering wheel with the car off.
    I haven't tried it on mine. Something to do today! :)
  9. sexyprius
    sexyprius New Member
    Hong Kong
    Great Job pk123!
    Since my prius body is very low and the bottom will crash some road pump when I drive through it , wanna ask if replacing this new strut will the car body be higher than before? How high is your prius body right now:)?
    Fostel likes this.
  10. James Finch
    James Finch Junior Member
    69
    Whitehall, Mi
    I'm thinking doing the bushings and possibly the sway bar links.
    First off the front strut assemblies and the lower ball joints (at least the drivers side for now even though I invested in both).
    Wondering if the bushings can be DIY Homebrewed repaired with some polyurethane or maybe even type 2 silicone and/or a wrap of some rubber sheet to tighten up the tolerance?
  11. Paul E. Highway
    Paul E. Highway Active Member
    199
    126
    Hawaii
    It’s just as easy to replace the bushings as trying to DIY Homebrew it. Do it at same time as sway bar links, sway bar needs to be disconnected on both sides to change out the bushings. Easy job if you’re already working in that area.
    douglasjre likes this.
  12. Ashy Anklez
    Ashy Anklez Junior Member
    Atlanta
    What brand did you choose. Are you having any issues?
  13. James Finch
    69
    Whitehall, Mi
    Yes, I'm thinking that's true. Challenging when I can drive quite a few miles with the expense of the bushings in gas.
    Went into the Toyota dealership to get my oil and oil filter changed along with an inspection. I got under also and confirmed the sway bar links are loose. The sway bar seems solid, so thinking bushings aren't required yet. Sway bar links are for sure.
    The front suspension, lower ball joints and what else inspected without the wheels in the air all seemed suitable. Got an extra little bounce, instead of an ideal stop when pushing down on the front suspension. The consensus seemed to be those are fine and maybe starting to get a little loose, though not bad or needing to be changed. Any thoughts regarding? Same with the lower ball joints.
    However, the culprit for the tire wear appears to be the wheel bearings that I'm thinking were caused by Discount Tire repairing a tire and not checking all the other tires pressure when they worked on the one. I drove a few thousand miles before I noticed and I've requested they rotate my tires at that same place and they thought they didn't need to based on mileage since new so they didn't do the free rotation and balance. Will have to dig through the paperwork or actually just call the Discount Tire I typically go to and bought the tires from in the morning to see when they did at the other Discount Tire location since I know where was performed very clearly.
  14. Paul E. Highway
    199
    126
    Hawaii
    I used the OEM sway bar bushings.
