New HV battery and doesn't run
Discussion in 'Gen 2 Prius Technical Discussion' started by Cybersurgeon, Jan 25, 2020.
  1. Cybersurgeon
    Cybersurgeon Junior Member
    45
    Reno,NV
    Four Touring
  2. Cybersurgeon
    45
    Reno,NV
    Four Touring
    It wouldn't hold a charge for the HV Battery. I thought I'd get a good deal and just replace the battery and voila . Not happening.
  3. Cybersurgeon
    45
    Reno,NV
    Four Touring
    I did and it's correct.
  4. bisco
    48,862
    going back to your first thread, it seems you never diagnosed all the trouble lights, but went ahead with a new battery on a hunch?
  5. bisco
    48,862
    how many open threads do you have on this, i can't keep up
  6. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    Have you tried using that Harbor Freight scanner (or whichever one you purchased) to pull the stored codes?
  7. Cybersurgeon
    45
    Reno,NV
    Four Touring
    I took it back as it wouldn't work on Prius's. I've ordered one from Amazon and will download the app and see if I can get codes.
  8. Cybersurgeon
    45
    Reno,NV
    Four Touring
    I think 2. My bad
  9. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Did u fix the hybrid battery issue?
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    yeah did you lol...
  11. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I fixed the hybrid battery what I didn’t even know him in real life. :/
  12. Cybersurgeon
    45
    Reno,NV
    Four Touring
    No not at all.
  13. George W
    George W Active Member
    909
    510
    San Antonio
    2K1Toaster ships them almost fully charged.
  14. Cybersurgeon
    45
    Reno,NV
    Four Touring
    I don't need that. I was hoping for suggestions on how to get the car running after I put a new battery in it.
  15. scargi01
    scargi01 Active Member
    784
    57
    Missouri
    Sounds very much like something was missed when reconnecting wires. Check that all connectors are pushed in all the way, on both the 12 volt and the hybrid battery. I recently did a hybrid repair on mine and when I was putting it back together I forgot to reconnect one of the 12 volt connectors resulting in warnings like yours. Get the codes read.
  16. Cybersurgeon
    45
    Reno,NV
    Four Touring
    I’m getting a scanner today yo read the codes
  17. Cybersurgeon
    45
    Reno,NV
    Four Touring
    It’s not pulling any codes at all!
  18. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    Which OBD2 reader are you using to pull the DTCs with?
    If the 12v was disconnected, that would clear the codes :unsure:
  19. Cybersurgeon
    45
    Reno,NV
    Four Touring
    It;s not giving any codes at all.
  20. Cybersurgeon
    45
    Reno,NV
    Four Touring
    It’s not getting any codes at all.
