Ac and smart key code on 09 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priuslover09, Jan 28, 2020.
  1. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I have the b1412 and u0141 code. Why are the ac and the smart key code on my Prius 09? Any ideas? Also I have the tire pressure light on.
    #1 Priuslover09, Jan 28, 2020
  2. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Here is the workup for DTC B1412 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/05/2044g/cib14121.pdf
    If the tire pressure light is lit, then you have an issue with one or more of the TPMS sensors.
  3. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
  4. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Well that accelerated rather quickly. It only took you a couple of minutes for that workup, which has to be a shop record :whistle:
    Hard to say how much, you should ask the dealer. Some have reported 6k+ for an 'ac replace', with parts totaling around 3k+.
    You could DIY and save a bunch, but you may have to remove and replace most of the dash depending on your 'ac replace'
    Here are a couple of pictures to help give you an idea of what one 'ac replace' entailed. Though yours could be easier.
    Raytheeagle likes this.
  5. bisco
    51,901
  6. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    How much dose it cost?
  7. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    That looks hard to replace
  8. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Ok so capital hill auto in dc would charge me between 200-500$ To replace or fix the ac problem.
  9. bisco
    51,901
    great price if they guarantee it
  10. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    should I set up an appointment with them for Friday at noon? I did work with them before.
  11. bisco
    51,901
    yes, but make sure they have hybrid a/c high voltage experience. many systems have been ruined by 'pro's' who don't have the knowledge or understand the differences.
  12. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Ok
  13. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Can u tell me why I have the smart key code? Is it something theycan fix?
  14. bisco
    51,901
    no, are there any symptoms?
  15. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Like what’?
  16. bisco
    51,901
    Sks acting strange
  17. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Can u explain?
  18. bisco
    51,901
    No. If you were having symptoms, you would know. Just ignore codes with no symptoms
    TMR-JWAP likes this.
  19. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
  20. bisco
    51,901
    i know, but there's no other way out
