08 Prius No Heat, blowing only cold air
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fishbones, Apr 17, 2011.
  1. bisco
    52,286
    no, seriously?
  2. Timothy Jones
    Timothy Jones New Member
    Georgia
    I am having the same issue, just one day NO heat! do you have info on where the pump in question is located?
    #22 Timothy Jones, Jan 29, 2020
  3. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Behind the left side headlight
  4. ChapmanF
    18,456
    Pretty sure the pump behind the headlight is for the inverter cooling. Electric pump for heat is nearer to the firewall, maybe under the inverter-ish.
    Timothy Jones likes this.
  5. dolj
    dolj Senior Member
    8,524
    4,326
    Wellington, New Zealand
    Pretty sure you're right Chap. :whistle:
