Reconditioning Experience with Hybrid Automotive's Prolong System
Discussion in 'Gen 2 Prius Main Forum' started by biglew8, May 16, 2017.
  1. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    They also sell battery modules for when they are too far gone to be reconditioned.
    jerrymildred and Raytheeagle like this.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    Read the user guide information on Hybrid Automotive web site. It talks about bringing down to 1v or less during reconditioning process.
  3. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    The Navy brings their NiMH batteries down to ZERO volts to store them. I'd try a charge and discharge before pulling it apart.
    Pixel XL ?
  4. Bunce
    Bunce Active Member
    320
    183
    Oregon
  5. ericbecky
    4,365
    3,209
    Madison, Wisconsin
    If I saw a failed module I would replace it prior to bothering to charge/discharge the pack.
    Leaving a failed module in place when charging/discharging can cause some weird behavior during the process.
  6. Bunce
    Bunce Active Member
    320
    183
    Oregon
    My car's been on charge for about 36 hours. I now need to move it unexpectedly, how do I quickly discharge to a safe level?
  7. Prodigyplace
    11,696
    11,317
    Central Virginia
    Careful!
    @jerrymildred killed a battery that way once. :(
    jerrymildred likes this.
  8. Bunce
    Bunce Active Member
    320
    183
    Oregon
    Well my 12v got too low so it's not going anywhere now anyway. But it would be good info. to know. I searched and couldn't find any recommendations but I know I've read it somewhere.
  9. Prodigyplace
    11,696
    11,317
    Central Virginia
    You mean something like this?
    From Battery Reconditioning Overview
    SFO likes this.
  10. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    Please try at your own risk, yada yada.
    I've safely made the vehicle 'ready' and immediately shifted into neutral (as you don't want the engine to start and blow up the battery), then turned on the AC until it discharged a bar on the screen.
    If you fail to shift into neutral in a timely fashion or accidentally touch the gas pedal, something bad may happen.
  11. Bunce
    Bunce Active Member
    320
    183
    Oregon
    No. what I remember reading was a method using the ac.
    Nevermind though, I put it on the discharger for about 10 mins then turned car, into N, ac on. All seems well. Except for a dead cell, but that's another story.
    jerrymildred and Prodigyplace like this.
  12. Fred_H
    Fred_H Misoversimplifier
    546
    473
    26
    Germany
    I can confirm that this works. I have also used exactly this method when I was in a hurry.
  13. srellim234
    srellim234 Senior Member
    1,193
    1,681
    Laughlin, Nevada
    When reconditioning, what I've done in the past is protected the 12v by hooking it up at the contact points under the hood to a Battery Tender. Easy 12v insurance and not that expensive.
  14. WilDavis
    WilDavis Senior Member
    2,489
    2,153
    49
    OK, Ladies & Gentlemen!
    Coronavirus scare, Nor'Easter bearing down on us, what better time to do a "shortie" on the ChuggyPig:
    20200322: 18:03: 235V 356mA
    20200323: 13:16: 248V 356mA
    20200323: 15:00: 248V 356mA
    20200323: 18:10: 248V. 356mA
    …so, roughly about 24 hours, stopped charging last night. Blue sky with sunshine today, about 4" snow on ground (…I swapped back to the summer wheels a couple of weeks ago (…buggeration!) :rolleyes: Stay safe, everyone! That's it until late June! ;)
    Raytheeagle and jerrymildred like this.
  15. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Sigh. I miss snow. It's 83F here right now. But I admit that by this time of year, I was getting itchy to start on the garden.
    Keep that ChuggyPig chugging! :D
    Raytheeagle and WilDavis like this.
  16. Tim Jones
    Tim Jones Senior Member
    1,687
    547
    SE Texas
    2011 Nissan LEAF
    Your probably going to need a new battery. Money better spend on new one. I had the exact same charger and discharger.
    #1176 Tim Jones, Mar 26, 2020
  17. jerrymildred
    11,491
    14,100
    Tampa, FL
    That post was two years ago. I wonder. I don't recall if he wound up replacing it yet or not.
    Tim Jones likes this.
  18. Tim Jones
    1,687
    547
    SE Texas
    2011 Nissan LEAF
    I post to some of the old ones to possibly help.
  19. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    Was your reconditioning process not as effective, and have you already disposed of the deluxe kit?
    At what mileage did you start reconditioning, and when did your HV assembly finally fail to deliver the performance you were expecting?
    I'd be willing to bet the OP still has the same battery, and most likely will have it for some time to come :coffee:
  20. dolj
    dolj Senior Member
    7,508
    3,773
    Wellington, New Zealand
    Pretty much stating the obvious. There two type of hybrid owners, the ones who are going to replace the battery and the ones who have replaced the battery.
    As to whether the money is better invested in the charger or saving towards a new pack, it is horses for courses.
    I bought my package some 5 years ago because I felt the pack was getting soft and was heading for failure. That car responded very well to the reconditioning and has been running great. On average I'm doing a recondition every two years. So for me, I don't regret the purchase and am very happy to prolong the life of the battery so I get more use out of the pack.
    SFO likes this.
