Did dealership really rotate my tires if wheel lock is still unwrapped in trunk?
Discussion in 'Prime Main Forum (2017-2022)' started by mrshred, Jan 26, 2020.
Tags:
  1. mrshred
    mrshred Junior Member
    New Jersey
    Just back from an awful experience at the stealership - 2 hours+ waiting for just an oil change and tire rotation on my 2017 Prime - with an appointment. I was reading the horrible reviews on Yelp for this dealership to kill time, and came across one that said one of their wheels came off after leaving the dealership. So I figured I better check the lug nuts on mine when I got home. I pulled the wheel covers off and was surprised to find wheel locks! Looked in the owners manual - nothing. Finally checked the tool kit in the trunk and found the key - still sealed and untouched in its clear plastic pouch. Does anyone know if the dealership has a set of keys, or did they just not bother rotating the tires. I got them to knock off the charge for the rotation in lieu of the long wait.
  2. schja01
    schja01 One of very few in Chicagoland
    1,732
    1,157
    Chicagoland
    2018 Prius
    They should have a complete set. They don’t want to waste time looking where you hid yours.
    If the locks were dealer installed they somehow did it without using the key that is still sealed.
    Elektroingenieur likes this.
  3. Rob43
    Rob43 Senior Member
    1,373
    1,044
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Yes.
    Rob43
  4. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    isnt tire rotation part of the initial 2 year free service?
    or did you not get that with the 2017?
  5. mrshred
    New Jersey
    This was the first service after the 2 year free service. Was going to do the oil and filter myself but got a coupon from the dealer for $45 synthetic change, so had them do the rotation as well.
    f
  6. NSXT
    NSXT Active Member
    137
    117
    Toronto, Canada
    2018 Prius Prime
    They have a Master Key at the service bay and they don't need ours.
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,125
    2,182
    Taylors, SC
    Yeah, there is the tooth fairy and the Easter bunny, too.
    Almost all of the so called "universal keys" are hammered on, grip the wheel lock with teeth and scar the chrome surface. There would be marks on the wheel lock body. If there are non on your particular locks, they were not removed.
    Toyota uses McGard locks that does not issue a "universal" key.
    Prodigyplace likes this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    OK..so you've already gotten responses that say YES, they rotated your tires, and NO, they didn't.
    Truth is? You're probably never going to know. The only thing you know, is that the dealership didn't touch the keys.
    If they put rotate tires on the service invoice? If they charged you? Might as well assume they did, because they aren't going to admit they didn't.
    With the bad reviews of this dealership, and your personal experience, I think the answer is to switch dealerships, and look at those YELP reviews BEFORE you're sitting in the waiting room having them do service work.
    Next time you can make it a bigger issue before handing your keys over, point out that you have wheel locks.
    I've even read posts where people go to the trouble of marking their tires with chalk, so they can tell the rotation has been done.
    But honestly, in this situation I just think your stuck never really being able to know. It's too late.
  9. Rob43
    Rob43 Senior Member
    1,373
    1,044
    2013 Prius v wagon
    #9 Rob43, Jan 27, 2020
    fuzzy1 and Trollbait like this.
  10. Salamander_King
    Salamander_King Senior Member
    10,964
    8,840
    New England
    I have marked my tires R1, R2, L1, L2 with a paint pen. So I know when or if they are rotated. Tire rotation twice a year to coincide with winter change over. Odd number tires (R1, L1) in front in odd number years (2017, 2019, 2021...). Even number tires (R2, L2) in front in even number years (2018, 2020...).
    #10 Salamander_King, Jan 27, 2020
  11. iplug
    iplug Senior Member
    2,450
    1,698
    Rocklin, CA
    I mark a small part of the stem of the front or back tires with a sharpie on all of our vehicles to verify such things.
    Unfortunately this proved useful for us on at least one occasion where tires were not rotated. The occasion did not happen at a Toyota service center, but a chain oil/tire/brake place where the adviser initially insisted at pickup that the tires were rotated. When I showed him how this was demonstrably incorrect he apologized and rotated them on the spot.
  12. George W
    George W Active Member
    909
    510
    San Antonio
    I recently vacationed a thousand miles away from home and realized my key was not in the car. It made me seek a local Toyota dealership in Georgia to change the tires back to regular lugnuts(They said they had a key). After reading this thread I found mine, and looked for tell-tale signs of forced removal. There aren't any.
  13. Trollbait
    11,328
    Even without locks, they might not rotate the tires. Know people that make a mark on a tire so they can check after to see if a rotation has been actually done, and caught places not doing it.
  14. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Luckily for me, when I'm at my dealership, I can see into their 52 service bays... I've actually been lucky enough to see my car(s) several times have the tire rotation done by looking out the waiting room window. I wish you luck and would probably go to another more reputable service department.
    As far as time, I have sat there and watched my car just sitting in the bay waiting for a mechanic to get to it. But they are pretty upfront about their time for me to wait, and they usually beat it.
    dig4dirt likes this.
  15. Chazman62
    Chazman62 Member
    108
    65
    Long Beach, CA
    2020 Prius Prime
    I wonder if the OP noticed the tire treads are more or less on the front tires than the rear?
    That would be a definite tell-tale sigh if the tire rotation was done for the first time in 2 years for his 2017 Prime?
  16. Mendel Leisk
    38,252
    The wheels should have been rotated several times with the US free maintenance?
    Just a thought about wheel locks: ditch them, get 4 more regular lug nuts? The special socket can get lost, and it's an extra hassle with every tire rotation. I did that a few years, got Gorilla nuts that were dead-rings for the OEM.
  17. fuzzy1
    10,048
    That is where a tread depth gauge becomes useful. See an example in Rob's post #9.
    Rob43 likes this.
  18. PT Guy
    PT Guy Senior Member
    1,085
    709
    Washington, the state
    Wheel locks on a Prius? Who is going to buy Prius wheels from a thief? The thief targets what he knows he can resell.
    Are the original lug nuts in the car in addition to the locking lugs? Or did they go back to the parts department bin to be sold to someone?
    My thought is that the locks are just an added profit item for the sales team. I refused them.
  19. schja01
    1,732
    1,157
    Chicagoland
    2018 Prius
    I believe the kit is 4 keyed nuts and 1 keyed socket.
  20. Elektroingenieur
    2,515
    3,253
    Three Touring
    It’s not a single, universal key, but rather the Wheel Lock Master Key Set, Toyota part number 09999-00110. This is an essential special service tool, so all dealers are required to have it, and the Master Index (PDF) says it’s kept in Drawer 16 of the SST Storage System, with its friends the Spare Tire Lock Master Key Set (09999-00310), TRD Master Key Set (09999-00410), and TRD Master Key Set Supplement (09999-00411).
