GPS- Distance and time to destination wrong
Discussion in 'Gen 3 Prius Technical Discussion' started by Ronald Thompson, Jan 14, 2020.
  1. Ronald Thompson
    Ronald Thompson Junior Member
    28
    East Williston, NY
    For the last few years I'd program the GPS and the mileage to, and time, to get to a known destination is incorrect. It over estimates both. It will add an hour + and 100+ miles.
    Any way to correct this. I was going to try disconnecting the 12 volt battery to see if it resets, but don't know what that will do to the cars mechanisms.
    Now just use the GPS on my phone.
    Thanks
    Ron
  2. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    If you live in a non metro area or no major highways near by, the car gps is a joke. I just wish there was a way to turn the gps live tracking as your driving so you don’t see the triangle pointer moving on the map.
  3. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    Did you program your home address correctly?
  4. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    What navigation do you have? In the OEM Toyota navigation (like the B9016) there is setting for the average speed on 3 different road types. That might be off. There is also a setting to avoid certain roads, like toll of highway.
    Does it give you the correct route but says it is much further? Does it maybe display kilometers and not miles?
    fuzzy1 likes this.
  5. fuzzy1
    10,550
    Is it showing the actual route you take? If not, is your nav system set to avoid certain types of routes?
    Are you driving significantly faster than speed limit (or what the limit was back in the few years just before this car was produced)? Or faster than it expects on some certain lower level back roads?
    Some of my nav choices (car / Garmin / Google, don't ) will initially pad some extra travel time on to long trips, allowing for some breaks that everybody should be taking. While I usually take even longer stops, extending the total trip time, occasionally I can do better (fewer / shorter stops) and watch the arrival time get significantly earlier throughout the trip. Only some of the systems do this, but I'm not awake enough at the moment to accurately say which. (No, I'm not driving now.)
    Ed Beaty likes this.
  6. Ronald Thompson
    28
    East Williston, NY
    The issue is both time and distance. The problem has surfaced in the last two years of an 8 year old car. So Km to miles would not effect the length of time to get where it's programmed. It's on miles. The issue is universal, place to place. But I have programmed in my correct address.
    The first 6 years the device would accurately state the correct mileage and time to destination. It would modify the time based upon driving situation. If I was driving faster then the speed limit, it would change the estimated time of arrival. It wouldn't modify the distance.
    I'm not talking about a small amount of time or distance. It would add 100+ miles on a 120 mile trip along with an associated time increase. The system is interpreting the incorrect distance.
    The question is how to correct it?
    Battery disconnect?
    Programming issue?
  7. fuzzy1
    10,550
    But is the route displayed on the map still correct?
    I'm still seeing insufficient clues ...
  8. Maarten28
    415
    224
    Netherlands
    My OEM navigation does not do that. It calculates time based on the average speed in the settings. Of course when you drive faster, the time goes down more rapidly, but it does not recalculate a new time.
    So I ask again: which kind of navigation do you have? There were a few very different navigation units installed in the Prius.
  9. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Difference such as?
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    This is a tough one. With an 8 year old unit, there might not BE a good fix.
    Most are supposed to "learn" your driving habits......speed mostly.....and make the initial calculation based on that.
    That wouldn't cause a distance error though.
    Check your navigation settings and look for something like "factory reset".
    If there is some bad data stored in the memory, that might clear it out.
    And no, removing the power won't do the same thing.
    I would ask if you have ever updated the map but that can be expensive and might not be worth the gamble.
    If it still gives you the right routing directions, it isn't a total loss.
