New brakes squeaking/creaking
Discussion in 'Gen 3 Prius Main Forum' started by markjosh51, Feb 5, 2020.
  1. bettergolf
    bettergolf Active Member
    490
    368
    Sanford NC
    Thank you.
    I'm still trying to understand why cars I owned for years and 100's thousand miles didn't develop a problem....maybe it's the climate where I live?
  2. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    I know people who said the same thing, they sold their cars before 100,000 miles.
    dig4dirt and Mendel Leisk like this.
  3. markjosh51
    markjosh51 Junior Member
    42
    North Hollywood
    I saw them taking the rotors along with the pads and they inspected them and yes they did grease them
    The first time because I can see it through the tires. I even took it to another mechanic who specializes in hybrid cars and he too said that he couldn’t find anything. I think I just need to break it in.
  4. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    I replaced rotors and brakes before, never made any sounds before nor to be broken in. In fact i had warped rotors which is best to be replaced and not resurfaced. Chances are they didn’t resurface anything, just put new unmatched pads on causing noise and billed you for resurfacing.
  5. markjosh51
    42
    North Hollywood
    I have heard about the bedding process. Maybe that’s what I will do. I will do it and post an update.
  6. markjosh51
    42
    North Hollywood
    Did you use oem?
