Code: P0304 head gasket?
Discussion in 'Gen 3 Prius Technical Discussion' started by HungryHungryHippo88, Jan 30, 2020.
  1. HungryHungryHippo88
    HungryHungryHippo88 New Member
    NOC CA
    Hey guys, took car to dealer after getting p0304 code at oreilly's and auto zone. Always good to make sure so i double checked.
    10 minutes after dropped off car at dealer.
    Engine light wasn't even on upon drop off.
    Came and went the last few times upon starting.
    Was getting rough idle and sputtering when lightly accelerating.
    Came and went for a little over a week.
    Took it in and awaiting word expecting new plugs were needed.
    Haven't put new plugs In yet.
    136,500 miles on it. Just had battery replaced under warranty a few weeks ago.
    Could this be a head gasket issue?
  2. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    No it’s cylinder code
  3. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
  4. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    When were the plugs last changed? And miles when changed?
  5. tgotr
    tgotr Junior Member
    34
    Southern Michigan, below da bridge
    No, a head gasket issue would result in the engine overheating after a short while and the oil looking milky due to coolant contaminating it.
    p0304 means Cylinder 4 is misfiring, which could be the ignition coil pack for that cylinder, or the plug
  6. Triparadox
    Triparadox Active Member
    201
    108
    I'm pretty sure mine didn't go to overheating when the head gasket issue was a thing. Also, the milky looking coolant is hard to spot. My head gasket was fucked up on 2 cylinders, and I couldn't even see any milky stuff from coolant, or the engine oil / cap.
  7. Mendel Leisk
    41,640
    Yes it could be. Try a leak-down test.
    Have you cleaned the EGR circuit and intake manifold?
  8. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Not replacing the plugs at its interval change may contribute to head gasket leak and not just limited to that.
  9. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
  10. Triparadox
    201
    108
    You mean spark plugs? Can you elaborate on how that affect the gasket? As far as I understand, head gasket issue is mainly caused because of overheating, or it simply just wear out specifically on Prius Gen III.
