2020 LE Shut Down/Off
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Adrienne A., Feb 11, 2020.
  1. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    I own a 2019 and my car experiences several idle features, such as lights turn off after 30 minutes or so. The engine will shut off going to battery mode if I don’t use the heat. I believe we need a bit more clarification if this is normal or this is an anomaly.
    Adrienne A. likes this.
  2. Adrienne A.
    Adrienne A. Junior Member
    2020 Prius
    No set time frame- there was a 24 hour period (perhaps a bit longer) a week or so ago, when it didn’t shut off at all. It could be 5 minutes or 2 hours. It usually does it at least once an hour, and often it’s multiple times an hour.
    Sometimes it might not do it for about 2 hours. I can’t figure out any sort of specific timing to it.
    It happens anytime I am parked and in Ready mode.
    Zero warning- just a click sort of sound then at nearly the same time the car shuts down/off.
    Yes, and no. It happens at many different times. It could be 5 minutes or 2 hours (or longer)
    I do not receive any sort of alert at all.
    Parked, and in ready, with or without A/C running.
    Both, sometimes it is locked, and sometimes not. I am always in the car if it is on, unless I am going to the trunk or something.
    #22 Adrienne A., Feb 13, 2020
  3. Prodigyplace
    12,625
    11,807
    Central Virginia
    Does it turn off completely when it shuts down? How do you recover from this shutdown?
    alanclarkeau likes this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    You've got us all intrigued.
    I (we) don't understand why you're "sitting" in the car with it POWERED UP for more than 24 hours? Are you camping in it or something. This is a very unusual sort of procedure.
    Running forever isn't something that a car maker would have designed into a car.
    pjksr02 and kithmo like this.
  5. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    rideshare?
