Gen 3 transaxle failure/fix at 193,000
Discussion in 'Gen 3 Prius Main Forum' started by Jeremy J. Ford, Feb 12, 2020.
  1. George W
    George W Senior Member
    911
    513
    San Antonio
    Have you measured the 12V battery from the front jump points under the hood? Is so, what was the number? What is the number measured after a 3 hour 'rest period'?
  2. Jeremy J. Ford
    Jeremy J. Ford New Member
    29
    St. Louis, mo
    battery voltage
    From rear it’s 12.45 from front it’s 12.35
    With lights on
    Rear 11.99 front jump point voltage 11.88
    #22 Jeremy J. Ford, Feb 14, 2020
  3. George W
    911
    513
    San Antonio
    Depending on who's scale is used, 12.35 is about a 50% state of charge, so you could be getting some weirdness there. Before you spend a couple hundred dollars on new, pull yours and see if the closest auto parts store can charge it up for you.
  4. Jeremy J. Ford
    29
    St. Louis, mo
    Ok. On my way!
  5. Jeremy J. Ford
    29
    St. Louis, mo
    Well battery tested good. From December 2019. Getting it charged up for good measure.
    George W likes this.
  6. Jeremy J. Ford
    29
    St. Louis, mo
    Gentlemen....I think I found the problem.
    A broken plug that goes to the transmission in the back of it next to the orange main wiring. Thank god that junkyards cut wires instead of disconnect them.
    first pic. On my car. See the 2 broken wires?
    Second pic. From the original transmission with the plug that came off the new transmission.
  7. George W
    911
    513
    San Antonio
    good eye. I wonder if this is a connection that is mentioned in the 'procedures' you referenced earlier?
  8. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    277
    Redwood City, California
    Transaxle breather!!!
    Awesome. I really thought there must be such a thing on these transaxles. I had asked earlier on here and was assured that the transaxle was hermetically sealed when you put the fill plug back in. That made no sense to me, but what did I know, so I just believed it.
    It matters because it means there is no concern for minute amounts of water being in the ATF, such as might happen from having an opened ATF container on the shelf. I.e., needing to be as careful as you would be regarding brake fluid. Any minute traces of water will simply vaporize at operating temperatures and exit through the breather, which makes a lot more sense than having it air-tight.
    Great work on this so far.(y)
    George W and ASRDogman like this.
  9. Mendel Leisk
    38,952
    Breather or not, Toyota does say to only use fluid from freshly opened bottles. I'm ok with that, it doesn't break the bank.
  10. Jeremy J. Ford
    29
    St. Louis, mo
    Well I used fresh fluid, and fixed the wiring and charged the battery. P lock malfunction still there. ‍♂️
  11. Jeremy J. Ford
    29
    St. Louis, mo
    I forgot I had techstream. Here are the codes:
    P0031
    P2237
    U0293
  12. George W
    911
    513
    San Antonio
    Still there after you cleared codes?
  13. Jeremy J. Ford
    29
    St. Louis, mo
    I didn’t clear them G. I can clear them with techstream? Is it obvious how I can do that? Never tried it. Don’t forget, I even forgot I had the program. Shows how much I use it.
  14. George W
    911
    513
    San Antonio
    I have no experience with Techstream, I use Dr. Prius for resetting. Sorry.
    Googling UO293 talks about ECUs not communicating over their network. I would be resetting connectors that I could access.
  15. Jeremy J. Ford
    29
    St. Louis, mo
    There is one Connector that I had trouble with. It’s the one on the side of the inverter. It was really tough to get it off, and I’m not sure it’s seated properly. The gray one, on the right side, passenger side, of the inverter. Can someone help?
  16. George W
    911
    513
    San Antonio
  17. ASRDogman
    ASRDogman Senior Member
    6,262
    3,336
    I also read is that same link about clearing the codes.
    Disconnect the battery. Jumper the two leads together, NOT THE BATTERY LEADS.
    The cables. That does some kind of "hard" clearing of the codes.
    It is possible you have a bad parking module.
    I would also check ALL connections. If you missed that one, you may of milled others.
  18. Jeremy J. Ford
    29
    St. Louis, mo
    I checked them again. Found nothing. Then pulled the fuses and sprayed with electric cleaner. Still same error. ‍♂️
  19. Jeremy J. Ford
    29
    St. Louis, mo
    Ok. This time I pulled the inverter apart. And I’m plugged wires to check. I think I found the problem. Bent connections in the gear plug in the front of transmission.
    so if you look at the first pic. The prongs inside are bent.
    second pic is prongs and plug on original transmission.
  20. Mendel Leisk
    38,952
    Finger's crossed they can be straightened. (y)
