Front Wipers 2008 Prius
Discussion in 'Gen 2 Prius Technical Discussion' started by tmorelli, Mar 4, 2014.
  1. tmorelli
    tmorelli New Member
    I just had my prius in for its 100k service, and now the wipers do not work. I am not sure if it had anything to do with whatever they do at the 100k check. It has been about a week since I got it back and the first time I tried to use them
    As soon as I hit the power button they move about half an inch. I can probably power off and on over and over again and get them to move across the entire windshield, although they are now about 4 inches up.
    I thought maybe the fuse was blown, so I took out what I thought was the wiper fuse (15A labeled WIP) under the driver side dash, and it was not blown. Interestingly enough, the wipers still jump when the power button is pressed and the fuse isnt installed
    Any advice? I live 2 hours from the dealer and have never had an issue with anything on this car. Driving back to the dealer is a large ordeal for me so I'd like to fix this myself if anyone has any tips
    Thanks!
  2. JC91006
    JC91006 Senior Member
    16,768
    8,565
    To operate the wipers, it's not a button, but a lever. I must not be understanding what you are doing.
  3. tmorelli
    tmorelli New Member
    Thanks for your reply. I am pressing the power button that starts the entire car while the wiper lever is in the ON position.
  4. Patrick Wong
    18,204
    6,505
    The WIP fuse is 30A. The label is above the fuse.
    You will probably find that the fuse is good. The problem may be with the wiper motor assembly or the combination switch on the steering column which controls the wipers.
  5. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Can you hear the wiper motor continue to operate?
    If you can hear the motor running while the wipers should be moving, I wonder if a nut came loose on a linkage or the motor. I had the nut on the drive link of the cantilevered wiper come loose and it stopped moving. After tightening the nut, all was fine again.
    Hmm...the wipers moving without the fuse installed is a puzzle. Does it happen only once, maybe due to some capacitive storage?
  6. redu
    redu New Member
    Denver
    Hello everyone, my windshield wiper keeps wiping by itself when it’s cold outside. I ain’t touching the lever but it continue wiping. Thanks
  7. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    Are they going on low or high speed? What happens if you try to turn them on while they're going by them self? Low speed? High speed? Single wipe? Washer?
