Canadian Tire Eliminator Ultra AGM Battery for Prius (w/Pics)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Siward, Nov 18, 2016.
  1. Siward
    Siward Active Member
    314
    128
    Toronto
    Winter is coming and I was afraid of the battery dying so I changed it. All measurements were made at 15 degrees celsius. As a reference, my multimeter measures Costco Kirkland batteries at 12.3V in store.
    - Old OEM battery purchase date: July 2012
    - Old OEM battery off voltage with car off: 12.23V
    - Old OEM battery with car headlights on: 11.9V
    - Old OEM battery with car on: 14.79V
    Since I live in Canada, I bought a new MotorMaster Eliminator AGM Ultra battery. It costs $199.99 CAD with a $20 core recycle charge plus tax. It has a 5 year replacement warranty with 9 year prorated warranty. It should have better CCA then the OEM one.
    - AGM battery voltage (measured in store): 12.45V
    - AGM battery not refundable if terminal shows signs of scratches or usage
    OEM battery is on the left. I snapped the photos in a hurry.
    The MotorMaster battery was a direct drop in. The OEM vent elbow seems to fit.
    52,352
    thanks, nice write up. congrats! i would throw a charger on it before installing.
  3. Siward
    314
    128
    Toronto
    Does a charger really do much? The voltage drops back down shortly after.
  4. Mendel Leisk
    41,865
    Good send off. That initial voltage is a bit low; might have been sitting a while. 3~4 amp smart charger's the best option. If you don't have one don't sweat it.
  5. bisco
    52,352
    the voltage will drop to whatever condition the battery is in. on a new battery, it should charge up to 13+ and hold in the high 12's, or i would return it. what's the build date?
  6. Mendel Leisk
    41,865
    Build dates are often coded. IIRC Canadian Tire puts sticker on them upon receipt, to at least keep stock in order.
  7. Tideland Prius
    16,611
    Not bad for an AGM. An OEM replacement is about $200 as well. (I think I was quoted a little higher than that!)
  8. Mendel Leisk
    41,865
    A couple of Vancouver dealership parts dept's quoted me $271, about 18 mo back.
  9. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Got mine for $170 plus the $20 back from the returned old battery (it's not a charge it's a rebate for the value of the lead), plus they were having a sale at the time and I got a $50 certificate to use in the store. So I combined the $20 rebate and the $50 certificate and purchased a "Genius" charger/maintainer, which was -also- on sale. Got it for about $40 out of pocket.
    Note to Americans, as Canadians we get to pay more for most products. It's a benefit of living in Canada. ;)
  10. Mendel Leisk
    41,865
    A charger is a must. The hatch on ours sat open for about 6 hours yesterday; a read of the voltage showed it down to 12.43 volts. Hooked up my CTEK 4.3 overnight, it's showing 13.22 volts this morning. That's way high due to surface charge, will drop back down to around 12.75 in a day, but an example of why a decent smart charger is invaluable.
    WilDavis and Raytheeagle like this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Also determining and addressing the cause of the open hatch for an extended period of time will help extend the batteries longevity:).
    Doug McC likes this.
  12. Mendel Leisk
    41,865
    Wife got distracted while unloading after a Costco run. I've done my share too: once left the driver's door hanging open for 18 hours. :oops:
  13. David Beale
    5,963
    1,989
    Edmonton Alberta
    You were just testing the battery, right? ;)
    Doug McC, WilDavis and Mendel Leisk like this.
  14. Mendel Leisk
    41,865
    Yeah it got "tested" again yesterday: the hatch got left open for about 6 hours. 'Nother charging session.
  15. OBJ
    OBJ Member
    62
    27
    Stouffville, Ontario, Canada
    I got the same battery for my car in the spring of last year and so far so good.
    scona and Tideland Prius like this.
  16. Mendel Leisk
    41,865
    @Siward , @OBJ , how are those Motomaster's holding up?
  17. Siward
    314
    128
    Toronto
    Still running. No problems. I got the battery the day I created this thread.
  18. Mendel Leisk
    41,865
    Thanks for that. Their current Prius battery is still called "Eliminator", the badging is a little different, but the specs maybe the same. Up to $225 now. Just for giggles I'll check with dealership, see what they're asking for the Yuasa or whatever it is now. I'd suspect it's over $300.
  19. OBJ
    OBJ Member
    62
    27
    It's holding up well, even though, I don't drive the car every day.
  20. Siward
    314
    128
    Toronto
    UPDATE: 7/27/2021: Canadian Tire had a $90 store credit promotion, so I decided to buy/replace my 12V battery as it is now 4.5 years old. I sort of regretted replacing it as it still looked like it would still last. It was just too much of a hassle to return everything.
    • old battery 12.29V while in the car
    • old battery 12.40V after out of car sitting for a week
    • new battery 12.39V, measured at store (red logo)
    • new battery 12.33V after it was installed in car
    The new battery cost $249.99 + $20 core charge + tax. The new battery has a red logo instead of a blue one. It seems the price of the battery has gone up by a whopping 25%.
    Canadian Tire no longer offers the 9-year prorated warranty. It is just a 5 year replacement warranty now. Everything else is the same, the battery is still a direct fit for the Gen3 Prius.
    For you folks in the US, this post is not for you. Canadian Tire is for us Canadians.
