Battery change
Discussion in 'Gen 3 Prius Technical Discussion' started by Black Prius, Feb 17, 2020.
  1. Black Prius
    Black Prius Junior Member
    Kołobrzeg, Poland
    Whether the battery Prius 2016 year fits the Prius 2010 year ?
    48,946
  3. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Not even close. The gen 4 battery is considerably larger for one thing.
  4. Grit
    Grit Senior Member
    6,112
    4,040
    Wilkes Land
    The 12v is not interchangeable
  5. Mendel Leisk
    38,214
    Yeah, either 12 volt or hybrid battery, neither is compatible.
  6. bisco
    48,946
    Yes, the modules will fit. Has to be nimh
  7. jerrymildred
    11,491
    14,100
    Tampa, FL
    Wait a minute, @Black Prius. Which battery are you asking about?
    Neither battery can be just swapped out. The 12V batteries are not the same size for one thing. However, the cells from a NiMH 2016 or newer traction battery will work in a Gen 2 or Gen 3, but you'll want to use all the cells so they match each other.
  8. bisco
    48,946
    Right
  9. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    Trim Two ONLY (not Two Eco), yes the modules can be used. It has NiMH. All other trims have Li-Ion modules.
  10. Prodigyplace
    11,696
    11,317
    Central Virginia
    Only Trim One or Two ( NOT Two Eco)
    jerrymildred likes this.
  11. Black Prius
    Kołobrzeg, Poland
    It is a pity because I have the opportunity to buy cheap with Prius 2016 and I wanted to mount it to my Prius 2010.
    I currently have 40% battery life
  12. Prodigyplace
    11,696
    11,317
    Central Virginia
    I just realized you are in Poland. The batteries in 2016 Prius vary by country. The advice I gave was for the United States.
  13. jerrymildred
    11,491
    14,100
    Tampa, FL
    IIRC, in 2020, only the AWD version has NiMH. I wasn't sure about other changes from year to year. So, rather than specify trim, I specified chemistry. :D But for 2016 specifically, yes, you're absolutely right.
  14. Prodigyplace
    11,696
    11,317
    Central Virginia
    2016 - 2018. That is why I mentioned Trim One that was introduced in mid 2017.
