I'm a Gen 3 owner too!
Discussion in 'Gen 3 Prius Main Forum' started by Hayman66, Feb 18, 2020.
  1. Hayman66
    Hayman66 Member
    92
    117
    After hitting 200,000 miles on our 2007 we decided to trade it in for something a little newer so we upgraded to the 2012 Pruis 4. I like the inside of this one as it reminds me of my very first Prius that was totaled by the hail storm. My son, who will be driving it for work daily, loves the fact that it has heated seats and bluetooth unlike the 2007 Prius he was driving. I kinda feel like a Pruis collector! :)
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I hope this Prius makes you as happy as the other!
    Hayman66 likes this.
  3. bisco
    51,546
    congrats! how many miles on her?
  4. Hayman66
    Hayman66 Member
    92
    117
    She has 76,000 and looks brand new
  5. bisco
    51,546
    Perfect time to clean the egr before she blows
    Tim Jones, Grit and Mendel Leisk like this.
  6. Hayman66
    Hayman66 Member
    92
    117
    So far it is making my son very happy!
  7. Hayman66
    Hayman66 Member
    92
    117
    EGR? I will have to google that!
  8. Mendel Leisk
    40,991
    Heed the man. (y)
    It'll be all good if you undergo this 3rd gen rite of passage.
    Come to think of it, I don't think @bisco has taken his own advice? Biding his time?
    Some boilerplate (and attachments):
    The simplest way to see where you're at, is to check the degree of carbon build up in the EGR pipe, a stainless steel connecting pipe between the EGR valve and intake manifold. Watch @NutzAboutBolts video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Two or three other videos linked there too, for the full cleaning of the intake manifold, full EGR clean, and Oil Catch Can install.
    Good thread:
    EGR & Intake Manifold Clean Results | PriusChat
    Another:
    Oil Catch Can, Eliminate that knock! | PriusChat
    Some tools worth having:
    E8 Torx socket (mandatory)
    E6 Torx socket (optional, but good to have, to remove the throttle body studs from intake manifold)
    3/8" ratchet wrench, regular and long handle, flex head, you can never have enough (or 1/2 plus reducer)
    1/4" ratchet wrench, or 3/8" to 1/4" reducer
    Ratchet extensions: you can never have enough
    Long needle nose piers, straight and bent tip
    Ratcheting 12mm box wrench (optional, but makes disconnection of the EGR cooler from exhaust easier)
    Torque wrench (3/8" and 1/4" both good to have)
    Floor jack and safety stands (or ramps): basically some method to raise front, if you need to take underpanel off, which you may need to, both for access and to recover dropped items.
  9. bisco
    51,546
    Idk, 18,000 miles on my engine, what do you think?
    I’ll probably never have more than 25,000
  10. Mendel Leisk
    40,991
    Ah...
  11. Hayman66
    Hayman66 Member
    92
    117
    Awesome! Thank you for all the info and the links. I will have my son check them out.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,517
    Bay Area, California
    2019 Prius Prime
    Never is a big word;).
    But why not try your hand at what you recommend (y).
  13. bisco
    51,546
    i have a hard enough time getting myself to do the things i should do, no need to make busy worrk. but if somebody blows a gasket before 25,000, i'll move it from the way back burner to the back burner.
    idk, unless something changes, i'll probably be dead before this thing hits 25k.
  14. Mendel Leisk
    40,991
    Don't take that "like" the wrong way, just I hear yah, lol.
    Raytheeagle likes this.
