I searched the threads and found diff answers about belts...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Allison Meggison, Feb 19, 2020.
  1. Allison Meggison
    Allison Meggison Junior Member
    71
    El cajon
    Does the gen 3 (2013) not have any belts or pulleys? I'm still trying to figure out why my engine overheats when I go up a steep hill for a mile or so
  2. Mendel Leisk
    41,912
    No belt driven water pump. No belts of any descriptions, if I'm not mistaken. Any warning lights? If so there will likely be codes, which will help.
    Any recent coolant change? Residual air pockets might result overheat?
    Raytheeagle likes this.
  3. Allison Meggison
    71
    El cajon
    There's only the overheating light when i'm going up a mountain or at a slant for more than a mile or so. No check engine light. I did bleed the air in the system about a month ago. Coolant seems full but its hard to tell. I haven't added coolant in over a month
    #3 Allison Meggison, Feb 19, 2020
  4. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    It does have a crank pulley. But I have no idea why, since it has no belts. Does anyone know why it has the pulley?
    First thing I'd do in this case is to get an OBD2 reader to see what the various temp readings are, directly from the ECU, vs. just going off the light coming on.
  5. ChapmanF
    18,555
    Do both radiator hoses feel nice and hot after the engine has warmed up to temp? Strong heat out of the heater? See coolant circulating through the plastic bottle (again, only with engine up to temp)?
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    My guess, and it is just a guess, is that as the engine also comes in non hybrid versions that do have belts, Toyota decided that one part number was easier than two.
    Toyota ZR engine - Wikipedia mentions that it is related to the 2ZR-FE.
    fuzzy1 and Raytheeagle like this.
  7. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    If you did search, how many belts does your car have?
  8. bisco
    52,395
    how many miles on her?
  9. fuzzy1
    10,603
    Yes, this is more important for this case than most other cases where Bisco reflexively asks. If the previous suggestions don't lead to anything, then I'd be thinking of the clogged EGR problem that has hit so many Gen3 Prii, and miles will be a hint.
  10. bisco
    52,395
    i'm just naturally curious :)
    m.wynn and fuzzy1 like this.
