valve stem seal DIY
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mola, Apr 6, 2018.
  1. Figster10
    Figster10 Member
    207
    61
    Sacramento
    Anyone know the cheapest option to remove both the camshaft and crankshaft rods? I am reading we need a tool sst 09023-38400. What is plan b? Lol
  2. ChapmanF
    15,998
    It's a 14 mm union-nut crowfoot, as you might use to open a brake line that was in the way, something like that.
    Those are available from other sources.
    What exactly is it that you're looking to do, and why? You're using some terms here that aren't real familiar.
  3. Figster10
    Figster10 Member
    207
    61
    Sacramento
    I am replacing valve stem guide seals. Oil is burning after doing other tests and no change yet. Most Prius mechanics in my area have suggested bad valve stem guide seals as a result of bad oil consumption with zero signs of leaks
    ASRDogman likes this.
  4. ChapmanF
    15,998
    You've mentioned the crankshaft a couple times. What's up with that?
  5. Figster10
    Figster10 Member
    207
    61
    Sacramento
    I have to remove the crankshaft and camshaft rods to access the valve springs to replace the seals. My only problem right now is making sure I have all the right tools and parts for when I start removing things. Time consuming and requires a lot of patience but this can be done.
  6. Mendel Leisk
    38,952
    Better?
    Tande and Figster10 like this.
  7. ChapmanF
    15,998
    That would make more sense....
  8. Figster10
    Figster10 Member
    207
    61
    Sacramento
    I've read tons of information on the job and got lost in the post lol.
  9. Figster10
    Figster10 Member
    207
    61
    Sacramento
    My apologies ‍♂️
  10. Mendel Leisk
    38,952
    We bumble along. ;)
  11. Elektroingenieur
    2,515
    3,266
    Three Touring
    Since 2006, the Toyota part number for the Union Nut Wrench, 14 mm, has been 09017-1C120, but I wouldn’t pay the list price (¥6,100) for one, even if it were available in the U.S. parts system. Alternatives include the KTC BNS3-14W, Sunex 971014 (at this writing, $5.63 from Home Depot), or PROTO J4914MHFL.
  12. Figster10
    Figster10 Member
    207
    61
    Sacramento
    Thank you very much
    Elektroingenieur likes this.
  13. Figster10
    Figster10 Member
    207
    61
    Sacramento
    With the head on and engine on car and instructions manual in hand why Is it so hard to lock timing chain tensioner? I get little slack but I'm scared if I do everything without locking timing chain tensioner I could screw myself when i put everything back together
  14. Mendel Leisk
    38,952
    Hopefully someone comes along, a second gen'r with experience. The 3rd gen Gasket Master videos don't help with that?
    Curious: did you work through the night...?
    Figster10 likes this.
  15. Figster10
    Figster10 Member
    207
    61
    Sacramento
    Still up right now, lol. It's the plunger I'm trying to push back so I can lock it.
    I have a feeling I may need a second person to turn cam 2 up top to put pressure on chain so i can lock it. Everything else makes sense to me it's just that frikkin plunger I need to lock. Lol
  16. Mendel Leisk
    38,952
  17. SFO
    SFO Senior Member
    5,297
    4,238
    Northern California
    Can't wait for oil consumption updates when all is said and done. Had you already tried piston soaks using a solvent?
    Since this gen3 thread is already going sideways, I will leave these gen2 links here.
    Gen2 Chain assembly : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/14/215vic1u/x040001.pdf
    Gen2 Overhaul / valve stem seals : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/14/215nyc1u/w040001.pdf
    Raytheeagle and Figster10 like this.
  18. Figster10
    Figster10 Member
    207
    61
    Sacramento
    I will definitely update everyone with my progress. I think I should've read a bit further into the instructions I saw a small detail about swinging the cam left and right to get some more room for the lock lol. I will try it out tonight hoping that does the trick.
    I've tried bg product which I heard was the top notch stuff but turns out it cleaned the valve cover only which lead me to believe it's the valve stem guide seals. Bad catalytic converter code, poor mpg, fried o2 sensor all point to seeping oil through the valve stems. Absolutely nothing else will work for this as I've tried seafoam, bg product and thicker oil. I rent these out a lot so I have two prius burning oil right now 1 qt every 1000 miles. I truly believe this being my 10th prius this will be the valve stem seals.
    SFO, mjoo and Mendel Leisk like this.
  19. ASRDogman
    ASRDogman Senior Member
    6,261
    3,336
    I don't coach anyone. The man is just smart.
  20. ASRDogman
    6,261
    3,336
    Once you slowly remove the tensioner, you can slowly squeeze it in a vise, then lock it.
